No oil pressure!!!!!!!!!
Old Apr 27, 2004 | 12:52 PM
Hollis's Avatar
Car: 82 Camaro Z28 Indy 500 Pace Car, 98 Firebird
Transmission: TH200
It ussually has between 35-40 but yesterday i changed the valve cover gaskets and today it droped down to the red. Anybody have any idea what might have happened
Old Apr 27, 2004 | 01:00 PM
ede's Avatar
ede
wire fell off the sender or the valve cover leaks and you lost all your oil
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
EDIT* damn ede beat me
Old Apr 27, 2004 | 01:51 PM
Hollis's Avatar
Transmission: TH200
thanks, I iknow its full of oil, where is the sender located?
Old Apr 27, 2004 | 01:53 PM
beedo's Avatar
Car: 1986 IROC CAMARO
Axle/Gears: 3.73 posi
above the oil filter
Old Apr 27, 2004 | 02:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
In a 82 car, it's behind the distributor.... a silver can about 1½" diameter and about 2" long with a slide terminal.... dark blue wire with a large black rubber boot goes on it
Old Apr 27, 2004 | 03:15 PM
Hollis's Avatar
Transmission: TH200
Is there 3 wires on the conector?
Old Apr 27, 2004 | 03:18 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it's CFI, maybe, I don't know for sure. If it's carb, no.
If you have a loose connector, try plugging it in and see if the gauge starts working.
Old Apr 27, 2004 | 10:20 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
If it was a CFI car, yes there are 3 wires leading to it. A combined pressure switch/sending unit.
Old Apr 28, 2004 | 12:08 PM
Hollis's Avatar
Transmission: TH200
Well only the center wire is left on the conector, it looks like the others had been cut off, and i couldnt find the rest of it. After i messed around a little while the guage started floting between 0 and 20. It used to have the crossfire but it had been swaped to a 71 LT1 350 by the previus owner. What will the lack of the 2 ouside wires do?, cause its been running fine with out them before.
Old Apr 28, 2004 | 12:44 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
The other 2 wires most likey are the wires that control the fuel pump relay. The remaining wire is the wire for the gauge. My car had the exact same issue. 2 of the 3 wires were cut.
Old Apr 28, 2004 | 01:01 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you poke around, you'll probly find that the two cut wires are twisted together....
its so that the fuel pump cuts off when oil pressure falls... except the switch fails and then the car wont run.
in the dark ages before the general public understood EFI and electronics (read: 80s) people bypassed stuff like that alot to "fix" things.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
