Blinker holds the light instead of blinking
Old May 3, 2004 | 10:21 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
The turn signals on my 82 do not blink when they are supposed to. All it does is turn on the light and keep it on until I move the lever back to the center. The indicator lights show the turn signals are keeping the light on also.
It started to do this a few days ago.
My dad said my flashed which is under or in the dash needs to be replaced and I could replace it myself.
Now I have to manually make the turn signals blink. arg
The worst part of the day is on the way home I got pulled by a civic.
Old May 4, 2004 | 12:34 AM
oldblueZ's Avatar
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
Yup, just replace the flasher. It should cost less that $5 at any auto parts store. It'll take a few minutes to get all the under dash padding off, but it's definately easier to replace a flasher than to manually blink the blinkers.
-Jesse
Old May 4, 2004 | 06:51 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It is probably not the flasher.
At least one light bulb is out. Walk around the car while it's supposed to be flashing, and replace the light bulbs that don't work.
Old May 4, 2004 | 08:04 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
yup, its designed to do that when a bulb goes out.
Old May 4, 2004 | 08:43 AM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
mine does it also but the cause of mine was a rock breaking out the signal housing. i have to replace the whole assembly on mine but it took me a while to realize why the light stayed on when i turned the signal on.
Old May 4, 2004 | 07:42 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Check your bulbs either in the turn lights in the front of back and see if one or more is out.
Old May 5, 2004 | 05:58 AM
Ryknow86's Avatar
Car: 84 Camaro Z28
Engine: carbed 350
the same thing happened to me. all i did was clean up the two grounds in the engine bay near the front headlights, and it worked. is that all thats messed up is the directionals?
Old May 5, 2004 | 07:59 PM
thatsme's Avatar
definately check your front grounds I have the same problem right now only on one side. I have a broken ground wire and just havent fixed it yet. Do the front lights work at all. I lost the marker and the turnsignal in front when I lost the ground
Wade787b
Sep 29, 2015 01:15 PM
Jk_Under
Sep 2, 2015 10:59 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
zeitghaist
Aug 18, 2015 07:33 AM
Omega
Aug 10, 2015 12:46 PM
