i can't get the timing to stay set
Old Mar 15, 2001 | 03:03 PM
chris1roc's Avatar
I turn off the car and restart to recheck it and the timing is back to were it started from. What am I doing wrong?
88 iroc
LB9 305 tpi
k, flowmaster, ADS chip
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
AIM - chris1roc
Old Mar 15, 2001 | 03:11 PM
Blade's Avatar
Did you disconnect the "set timing" connector on the firewall ? Did you tighten the distributor clamp ? Expand on this a little bit... what exactly did you do ?
92 Z28 5.7
Trick Flow 23° heads, XR270HR-10 cam, Accel intake base + ported TPI, TES headers, Flowmaster catback, MSD ignition
#24 SVO injectors, 1LE aluminum driveshaft.
Click here to see my car at Truspeed.org
Check out Truspeed
Check out the Bin Archive
Old Mar 15, 2001 | 03:16 PM
chris1roc's Avatar
I unpluged the distributor plug undid the bolt then I set the timing at 10 then I turned the car off started it again and the timing was back to were it was when I started. I did this a couple times already.
88 iroc
LB9 305 tpi
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
AIM - chris1roc
Old Mar 15, 2001 | 03:50 PM
JETHROIROC's Avatar
If you unplugged the connector to the ignition module in the distributor that's your problem. Like Blade said, disconnect the ESC bypass (tan wire) behind the passenger side strut tower and try again.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, Accel coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Ruger P95DC, hot wife, new oil filter,
thick rubber floormats, towels in the seats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Mar 15, 2001 | 04:05 PM
Blade's Avatar
And also you didnt say if you tightened the distributor clamp back on! That's very important! LoL
Old Mar 16, 2001 | 11:13 AM
chris1roc's Avatar
I disconected that wire, tan with black stripe and a black connector, before I set the timing. Do I need to reconect the wire before I shut the car off? Do I need to tighten that bolt before I shut the car off?
88 iroc
LB9 305 tpi
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
AIM - chris1roc
Old Mar 16, 2001 | 12:04 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Where is this shutting the car off **** coming from? Here's how you set timing. If you follow thios procedure it is not reverting back to where you started.
#1- disconnect the tan/black wire ONLY
#2- startt the car
#3- Check the timing
#4- If it requires adjustment, loosen the distributor bolt and move the distributor until it is where you want it.
#5- tighten the bolt back down
#6-recheck the timing to make sure it didn't move while you tightened the distributor.
#7- turn off the car and reconnect the tan/black wire.
Thats it. When you set the timing you are making a physical adjustment on the distributor that can't be changed unless your distributor has moved (which is why you tighten it.) The only other possiblity is your pick-up coil (or some associated piece like the reluctor, etc.) is going bad which i suppose could let the timing wander around, but this wouldn't be consistent, i.e. it wouldn't always back you down to where you started, your timing would jump around unpredictably.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Mar 16, 2001 | 02:59 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
When setting the timming you are actually setting the "baseline timming". The ESC (Electronic Spark Control) controls the timming after you reconnect the by-pass plug. That is why you see the timing mark in the same position after reconnecting the plug.
Also don't forget to disconnect the battery after reconnecting the plug to reset the trouble code in the computer (a code will appear when running the ESC in by-pass mode).
[This message has been edited by Ozzy88GTA (edited March 16, 2001).]
Old Mar 19, 2001 | 09:15 PM
chris1roc's Avatar
thanks
88 iroc
LB9 305 tpi
k&N, flowmaster, ADS chip
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
AIM - chris1roc
Ghettobird52
Jul 5, 2024 11:18 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
apo_bailon15
Mar 28, 2016 05:20 AM
ezobens
Aug 19, 2015 10:29 PM
perZ
Aug 15, 2015 01:17 PM
