Water spits out muffler when I startup?
Old Mar 21, 2001 | 03:28 AM
MATEOZ28's Avatar
I think its water anyway. The car has bee running real rich and it has a bad idling problem. A few times I've started the car I notice black and clear liquid splattered on the cement behind the car and I felt inside the exhaust tips and sure enough they are wet. The car has bee sitting for about 6 months in a garage and I used the fuel treatment called STABLE and have drivin about 150mi with it acting like this. I have been hearing a vibration from the exhaust and my muffler guy checked it out and said "because its been running so rich youve broke the catylitic converter" He said I'm licky I didnt melt it. What cold the problem be?
Old Mar 21, 2001 | 03:29 AM
MATEOZ28's Avatar
BTW I have a 1991 Z28 with a brand new 383.
Old Mar 21, 2001 | 03:35 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
Mateo
I dont think I would worry too much my 91 Z28 dose the same thing when it sits and has time for moisture to build up inside exaust
it's not excessive is it??
Hecubus
http://www.tweak3d.net/temp/z28.jpg
91-Z28 305 Tpi "G92" mods-- K$N/Foil/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/ 100-150 Nos Wet Plate System/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel & Oil Press Guage's
Old Mar 21, 2001 | 08:12 AM
idrag2's Avatar
Its more than likely condensaton "spelling sucks" but n e way I have a 89 formula and on certin days when the humity is right mine will do the same thing...
Old Mar 21, 2001 | 10:21 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Yeah, it's completely normal. Water is a byproduct of combustion, and when the exhaust system is cool the water vapor will tend to condense on the tubing, then run out the back. Once everything is warm the water stays as vapor through the exhaust.
...ed
Old Mar 21, 2001 | 11:04 AM
greearhr's Avatar
Running rich agravates the water production in the exhaust.
Old Mar 21, 2001 | 11:12 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
like ed said this is normal
1991 banditt2 #130 of 600
Project 350 TPI Banditt2
<A HREF="http://clubs.yahoo.com/clubs/streetdawgracing" TARGET=_blank>
http://clubs.yahoo.com/clubs/streetdawgracing</A>
http://photos.yahoo.com/tonysams72
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation
Old Mar 21, 2001 | 11:53 AM
MATEOZ28's Avatar
Thanks you guy's. I was pretty worried
sheachopper
Jul 31, 2019 11:27 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
