Starter housing split in two. Looking for why
Old May 12, 2004 | 03:01 PM
Camarogeddon's Avatar
Car: '85 Camaro Z28
Engine: 350 carbed.
Axle/Gears: 9 bolt, 4.11's
Bought an '86 Z28 with 305 TPI in febuary.
previous owner had changed the starter, so it is less than a year old (looks like it is true, judging from how the thing looks)
Tho, it gave up on me here the other day, so i bolted it off, and found this (see linked images). no wonder it couldnęt get a grip. But, anyone have any clue as to WHY this may have happened, i don't want to wreck another starter.
may naturally have been a material fault, but any clues is appreciated.
images:
Pic1
pic2
-Camarogeddon
Old May 12, 2004 | 03:08 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You are the 2nd person in about a week to post with a cracked starter.
Old May 12, 2004 | 03:44 PM
justanothercar's Avatar
Car: 85 z28
Engine: 355
Without seeing the pics(they took too longTry..........
Wrong starter
Worng starter bolt
Bent starter bolt
Loose starter bolt
Dropped starter
Maybe even shims................
:lala:
Old May 12, 2004 | 04:07 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Here is a condensed version for easy viewing.
Attached Thumbnails Starter housing split in two. Looking for why-starter1.gif
Old May 12, 2004 | 04:09 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
second shot
Attached Thumbnails Starter housing split in two. Looking for why-starter2.gif
Old May 12, 2004 | 11:44 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
most break cause the front mounts have been taken off and never replaced
Old May 12, 2004 | 11:49 PM
Jproz1167's Avatar
Old May 13, 2004 | 12:09 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Can't see the front of the starter, so I can't tell if it has the stud for the forward mount bracket or not. The previous owner may have put a starter on that didn't use a forward mount bracket when he replaced it.
Old May 13, 2004 | 05:42 AM
ede's Avatar
ede
may have been because of hardwear store bolts instead of starter bolts.
Old May 13, 2004 | 05:50 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Hmmmm. Those pics look oh too familiar. I posted pics of my starter in a thread I started a little bit back. Mine turned out to be a shimming problem. (Or at least I hope it was a shim problem ) Believe it or not, after numerous starts it is possible for the stress of the starter gear going against the flywheel to crack the housing like that if not properly shimmed. I'm not saying that that is your problem but that was mine. After putting in some shims I haven't had a problem yet. Hope this helps. & Here's the thread if you wanna see my starter
https://www.thirdgen.org/techbb2/sho...hreadid=237969
Old May 13, 2004 | 09:38 AM
travelinman's Avatar
Car: 89 RS, 91 GTA
Engine: lo5, lb9
Transmission: t5, a4
Is your timing ok? or did it backfire on startup? that can put enough torque on the starter to snap the head like that, especially if the brace on the back of the starter isn't there
Old May 13, 2004 | 09:44 AM
ljnowell's Avatar
hmm?
Old May 13, 2004 | 11:18 AM
Savannah Dan's Avatar
Bad alignment + cheap starter =
Get a good starter, follow the shimming directions that should come with the starter, and fix that oil leak and you should be fine for quite a while.
Old May 13, 2004 | 12:24 PM
Car: '85 Camaro Z28
Engine: 350 carbed.
Thanks for replies, gave me a few ideas, and it looks like it may be a combination of factors, judging from what you guys say,
the main being that it wasn't shimmed, second: one of the bolts was an odd one, witch was about 1/3 inch too long, and the guy mounting it used a nut to space it out, and thirdly, when i studied the thing closer, there were markings from where the nut had pushed on the housing when the bolt had been tightened, same place where the crack runs. (see attached pic)
closeup of damage
Thanks for the clues.
-Camarogeddon
Old May 13, 2004 | 12:45 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
closeup of damage Thanks for the clues.
-Camarogeddon
id be willing to say that the spacing that a previous person did to it with a nut is the majority of your problem go to the parts store and buy the right bolts and as said before shim it and you should be fine ...
budowski
Carburetors
Oct 2, 2015 10:16 AM
sahlomonic
Sep 20, 2015 07:15 PM
Denricci22
Sep 18, 2015 09:02 AM
Cleotiz
Sep 16, 2015 08:02 AM
Formula_88AE
Sep 3, 2015 01:47 PM
