Cam question
Old May 12, 2004 | 03:41 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
Cam question
I have a question regarding cams.
I want to change my cam in the future but what to choose. I dont know anything about lift etc. I guess my engine has what some people call Peanut cam so i want a better one.
Can i change it whitout changing anything else in the engine?
Old May 12, 2004 | 11:00 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Do you have a roller block? What heads?
If its a roller block, you can re-use the factroy roller lifters. New springs are advisable, however. With new springs comes new retainers and locks. Whats the budget like?
Old May 13, 2004 | 05:41 AM
ede's Avatar
ede
depends on what cam you get what you need to change. at a minumin you'd need to change cams, lifters (if flat, rollers could be reused) springs, and retainers. go to comp or lunati web site and you can read a lot of good info on cams.
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
