Spark Plug Changing tips?
Old May 14, 2004 | 12:55 PM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
I am gonna change my spark plugs soon for the first time. I bought the car used so I have no idea when they were last changed and this is my first car so I have never changed plugs before. Anyone have any tips for me??
Old May 14, 2004 | 01:08 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
go at them from under the car.
if you can find one, buy a telascoping socket.
be prepared to swear alot.
Old May 14, 2004 | 01:24 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
And use plain old Delco plugs, but if you fancy so called "performance plugs" use Delco Rapidfires!
Old May 16, 2004 | 10:35 AM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
If you have headers consider the BOSCH +4s ... alot of guys dont like them, but if you are cramped for space ie. DYNOMAX headers, these plugs are shorter than DELCOs. Also, dont be afraid to buy a spark plug socket and grind it down to make it shorter to fit over the plugs. The rubber grommet on the inside of the spark plug socket can be removed for extra clearance.
Most importantly do not forget to warm the engine up first to ease the plugs out and put a little oil on the threads of the new ones.
Happy wrenching
POZ
Old May 16, 2004 | 11:39 AM
JokerRS's Avatar
Car: 92RS
Engine: 357
I have headers and use a offset box end wrench to break them lose. It works great
Old May 16, 2004 | 12:26 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
First buy headers, then remove manifolds, then remove plugs, install new plugs, and install headers. actual working on plugs time: about 3 minutes.
but seriousally, stick w/ the delco's, I've never heard anyone complain about them and people always complain about performance ones. You might want to replace your wires too, i did delco's and taylor 8mm wires w/ my exhaust this winter and got 3mpg out of the deal.
-chuck
Old May 25, 2004 | 01:01 PM
Arctic White 91 RS's Avatar
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
Make sure you check the gap on the plugs. For my 91 RS w/305 they should be gapped at 35. Plugs don't always come out of the box gapped correctly. If you do the wires also do a distrubtor cap and ideally a new coil. Keep the old coil for back up.
Old May 25, 2004 | 10:23 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
What coil would you recommend getting?
Old May 26, 2004 | 12:42 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I have edelbrock TES headers on mine with the air-tubes cut off.
I easily get my plugs from uptop. Probably becuase I do not have anything under the hood anymore. I just use a spark plug socket and a wrench to get all mine out. Its cake.
Old May 26, 2004 | 12:47 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
MSD Blaster #8226
eightsixseven
Dec 16, 2024 01:50 PM
apo_bailon15
Mar 28, 2016 05:20 AM
evilstuie
Feb 28, 2016 03:33 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
