Need help identifying part - car is down until I get it!
Old Mar 21, 2001 | 10:43 AM
R.C. Righter's Avatar
Having coolant leaking problems. I think I localized it to a piece that I then broke (it was weak). The piece is screw in 'nipple' fitting in the passenger side end tank of the radiator. The heater return hose mounts onto it. This is an 86 TPI T/A. The dealer can't find a picture of the part. I sincerely hope it's factory and not some part of an aftermarket radiator. Anyone confirm for me? Anyone get a part number?
R.C. Righter
86 Trans Am
Old Mar 21, 2001 | 11:00 AM
greearhr's Avatar
Take the fitting to a local radiator shop. They'll have it.
Old Mar 21, 2001 | 04:36 PM
Guest
Guest
Posts: n/a
The factory radiator has plastic end tanks, so yours has been replaced with something else if that fitting screws in. Take the fitting to a decent parts store, or a radiator shop as suggested above.
Old Mar 22, 2001 | 07:28 AM
Thanks for the help, guys. I actually called the GM parts warehouse and had them pull radiators and figured that this must be an aftermarket one. I plan to attempt to locate a brass fitting to use there.
R.C. Righter
86 Trans Am
Old Mar 22, 2001 | 07:11 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
The aftermarket radiators sometimes use a plastic nipple..hehheh...I said nipple..huhuh..oh, where was I..
anyway, the plastic nipple screws into the tank and has a rubber gasket.
Any radiator shop should be able to fix you up.
(huhhuh, I said nipple, screw, and rubber all in the same thread....hehehh...I'm a dork.. )
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
Old Mar 23, 2001 | 06:29 PM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Engineboy:
</font>
EB,
I can say "sphincter", too, but I'll bet you can't name the place on an airplane that a pilot sits (no, not the left seat), or the name of the little twist-open drain fittings on the radiator and sides of the block, or the annoying little hard-shelled scavenging insect that can survive almost anything.
Try it...
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Old Mar 23, 2001 | 06:35 PM
Neo's Avatar
Neo
Uh, Vader you lost me. Or was that the point?
Mike Kenny
1991 Chevrolet Camaro RS 305 TBI
My Website
Administrator at Auto-Clubs.net
My Baby
Old Mar 24, 2001 | 12:14 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Vader is again right...you can't type ****pit, pet****, and ****roach and have it show up.......
but you can type uranus....
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
1992 Trans Am
May 10, 2023 07:19 PM
Linson
Aug 21, 2015 02:12 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
