How much oil pressure at idle?
Old May 18, 2004 | 03:34 PM
83TransAm's Avatar
Car: 1983 Trans Am
Engine: 355 SBC
Transmission: 700R-4
How much oil pressure should I have at idle?
When my car is cold, I have about 40 psi at idle.
When my car warms up to 190 degrees, it drops to about 20 psi at 600 rpm. As soon as I touch the gas, it shoots up to about 40-45 psi at about 1500 rpm. Is this normal?
Steve
Old May 18, 2004 | 03:42 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's roughly normal behavior for the engines in these cars.
Old May 18, 2004 | 04:51 PM
Matt_Ky's Avatar
Car: 1998 Camaro Z28
Mobil One Full Synthetic Oil
75K Miles LO3
45 psi at idle cold ~600-700 rpm
30 psi hot idle back to 40-45 1500 rpm
So, I would say you are in the ball park.
How many miles on the engine?
Old May 18, 2004 | 05:54 PM
GenghisJohn's Avatar
Car: 1991 RS
Engine: 5.0
Those numbers sound OK...mine are lower.
Old May 18, 2004 | 06:30 PM
RedIrocZ-28's Avatar
Car: Iroc-Z
Engine: 355 AFR'd HSR
Usually anything lower than 20psi is an indication that your bearings are worn down pretty far. My car idles at roughly 30psi and will go to about 50-60 upon acceleration. If you get under 20psi at idle I'd very seriously consider a rebuild before you spin a bearing on the crank or the rods and cause yourself to cry because of all the machine work/replacement parts buying you'll have to do. 20psi seems VERY low.
Old May 18, 2004 | 06:44 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Increase the idle speed a little and forget about it.
Old May 18, 2004 | 07:03 PM
83TransAm's Avatar
Car: 1983 Trans Am
Engine: 355 SBC
My engine is just rebuilt, brand new bearings, crank, rods, everything. I just checked the oil and it is full.
The car usually idles pretty high, sometimes up to 1000 rpm. So when that happens, I have plenty of pressure.
I only run mineral oil, as the engine only has about 1250 miles on it, with some Lucas Oil Stabilizer in there. That might be some reason as it makes oil stick to surfaces instead of washing off them.
Steve
Old May 19, 2004 | 12:08 AM
MotorCityMuscle's Avatar
I would expect a little bit better numbers out of a fresh rebuild, but thats still ok.
Hows the car coming, Steve?
Old May 20, 2004 | 11:48 AM
83TransAm's Avatar
Car: 1983 Trans Am
Engine: 355 SBC
The car is great! I got a lot of the bugs worked out and it's finally becoming the car that I wanted it to be. Although I found out over spring break that the engine is too powerful for the transmission and had to get the tranny rebuilt. Other than that, it's lookin good.
Steve
Old May 20, 2004 | 12:29 PM
Good news! If you're back in Redford for the summer months, just gimme a call if you ever need help with anything.
Old May 20, 2004 | 10:27 PM
83TransAm's Avatar
Car: 1983 Trans Am
Engine: 355 SBC
I am back in Redford for the summer. If I have any issues I will definitely give you a call, but right now I am looking to sell/trade my car for something a little more economical. By the way, what are you runnin right now??? I can never keep up with your car adventures!
Steve
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
