what type of gas
Old May 18, 2004 | 06:39 PM
nitrospaz19's Avatar
Car: 86 Trans Am.....
Engine: 305 T.P.I
what type of gas
What type of gas does everyone put i nthere car? I always put super but wondering if u could put somethng less without making the car run like crap. ANy help
Old May 18, 2004 | 07:39 PM
mellissalee03's Avatar
Car: 1982 Camaro Berlinetta
Engine: 5.0L V8
I always use unleaded.... i've used Plus blend like once and didnt notice too much. My brother always put in premium whenever he drove my car and said that it runs better with it.
Old May 18, 2004 | 07:41 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You only need to run the minimal octane you can without any knock. If you go too high on the octane you can actually lose power. If you have stock heads (9.3:1) with a little base timing added you can get away with 89. 0* base and you can use 87 all day long.
Old May 18, 2004 | 08:31 PM
nick418's Avatar
Engine: L98, Hemi 6.2
i use any SUPER gas, mostly at a MOBIL, high octane
Old May 18, 2004 | 08:58 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Are you wasting money or do you need it?
Old May 18, 2004 | 09:03 PM
Engine: 5.0L V8
What do you all mean by "knocking" ????
Old May 18, 2004 | 09:12 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Knock is pre-ignition. That means that combustion is starting before the spark plug sets it off. It is caused by numerous things but the most frequent is improper fuel selection and improper timing. Audible ping will sound like marbles in a can. The sound you hear is the cylinder walls actually vibrating. It is the single worst thing that an engine can withstand. If you have a relatively low compression ratio and mild timing you can get away with low ocatne fuels. Using anything higher will delay ingniton and can reduce power. Octane numbers does not translate to "better" or adding "more power". Now if you have a high octane motor or have a lot of timing too low of an ocatne can cuase knock. The heat generated in the compression stroke will cause the intake charge to pre-ignite before the piston reaches TDC. A higher octane fuel requires much more heat to ingnite and will not do so until it is introduced to the spark.
Old May 18, 2004 | 09:17 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Use the lowest octane you can, there is potential for more power in the lower octanes. In some instances you may cause carbon build up in your combustion chambers with the higher octane stuff.
Engine Knock
Old May 21, 2004 | 12:18 PM
nick418's Avatar
My dad owns a MOBIL GAS STATION so i shop there, hell sometimes i get free gas
Old May 21, 2004 | 09:11 PM
nick418's Avatar
higher octane gas looses power??????? i thought High Octane gas (Super) is much cleaner and better gas for the engine.. I mean thats one of the reasons its more expensive then the other gas i mean they dont charge more for nothing ( Super $2.30 a gallon, Special $2.24 a gallon, REG unleaded $ 2.15 a gallon)
Old May 21, 2004 | 09:15 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Another one falls for the marketing.....
I'm in the wrong business. No wait, I am in the advertising industry, sort of.
We joke that we charge huge corporations millions of dollars for equipment so that they can charge other huge corporations billions of dollars to attempt to convince our children to buy this or that brand of colored sugar water.
I guess it's all about the same.
Old May 21, 2004 | 09:33 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
You know you're not surprised. Look at all the crap that goes on, from American Idol to the Patriot Act.
The democrats have the best one now, they rip the republicans on gas prices, and rip them on America consuming too much oil/oil products as well. Be a Democrat - Have it both ways!!
Nick, here is a primer.
There are tons of site thathave info. When you have the time go through a search on the board as well as the net.
Old May 23, 2004 | 08:48 AM
84 Restore's Avatar
Car: 1984 Z28 camaro HO Gun metal Gray
Engine: 305,L69 H.O. rebuilt
frEE GAS Riiiiiiiiiiiiiight
Your stealing it arn't you
Old May 23, 2004 | 10:04 AM
nick418's Avatar
damn strait..... when i need it badly all i do is pump the gas, after im done i go to the cash register and the print receipt write my name and then take off, and usually dad pays for it haha
Old May 23, 2004 | 07:20 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
It can if your motor does not need it. If your octane is too high for your particular timing and compression ratio the air fuel charge will not ingnite when it is supposed to. Higher octane fuels need to be matched to higher than average compression ratios and timing curves. If your fuel is being ignited when it is not suppoosed to you are loosing power.
Old May 23, 2004 | 07:26 PM
nick418's Avatar
really? well does a L98 350 TPi V8 need a high octane gas? i always put in in and runs great, one time i put reg and it didnt run as well it seemed... And my jeep to , i put super in it and today i added reg and it didnt run good wit reg..... i dont kno.
Old May 23, 2004 | 07:29 PM
nick418's Avatar
anwyas i get gas FREE haha . insurance is a diff story tho , ihave to pay both the maro and JEEP
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
Hello, Michael
Sep 11, 2015 01:10 PM
