Heat pouring into cab, whats going on?
Old May 20, 2004 | 07:02 PM
badapple's Avatar
Car: 1987 GTA
I've owned the car for going on seven years and finally..finally started to rebuild the car up. I've had this problem the whole time and finally have the means to really break down and fix it.
My problem is heat..its just pouring into the cab from the heating vents. The heater is off and its pushed to the cool side of the heat adjuster but still the heat comes. The heat doesnt pour out as if its set on the high fan setting but it does come pretty strong the more you drive it, damn annoying.
What do you guys think? Something wrong with the heater or maybe a hole in the fire wall? Something?
Old May 20, 2004 | 10:44 PM
Vader's Avatar
I would guess that you need to adjust the cable for the temperature air door on the heat/AC ducts.
Old May 20, 2004 | 10:58 PM
ljnowell's Avatar
Really, how does one go about this, not to hijack or anything, but I am greatly interested.
Old May 21, 2004 | 01:03 AM
badapple's Avatar
Car: 1987 GTA
Like ljnowell said, ....how?
Old May 21, 2004 | 01:14 AM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
Under the pass side of dash there is the lower panel. (The one you have to take out to drop the ECM). I believe it is under this panel. There should be a cable running from the controls to the blower motor/heater blend door. I am not totally sure, because one of my techs fixed mine for me. And those guys like to keep all their secrects to maintain job security
Old May 21, 2004 | 01:18 AM
badapple's Avatar
Car: 1987 GTA
So you had the same problem or a similar one jconrad?
Old May 21, 2004 | 01:26 AM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Mine was stuck on heat, so my A/C wasn't workin. All he did was go under there and like adjust or tighten a clip that held it in place. Once you are under there, I bet you'll be able to figure it out.
Good Luck, and keep me posted.
Old May 21, 2004 | 10:33 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I have my dash ripped apart, i can grab pictures of the cables in reference tonight, after work and have them up by tomorrow, if you would like.
Old May 21, 2004 | 10:41 AM
badapple's Avatar
Car: 1987 GTA
Yea that would be a big help, I'm wanting to jump into it tonight but it might have to wait a little while. Either way pictures would be a great help
Old May 21, 2004 | 11:03 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
You got it. I have them up by tomorrow morning for you.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
TBRays98
Sep 6, 2015 05:05 PM
