which HEI distributors do you recommend?
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
just curious what you have or brand you recommend?
also does it matter to have a 50state legal one or not?
can a smog tech notice?
Car: '02 Z06
Engine: L33 5.7
msd is soo expensive over leading brands, is their a cheaper alternative but still get the HEI? it seems mallory doesnt look to bad.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Whats wrong with a GM-made HEI? With the right parts in it, it would work as well as anything else, and probably cost a fraction of the what the MSD or Mallory peice would cost.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Yeah... The stock one should be fine. Theres no need for the high output aftermarket stuff on an LO3. Just make sure the ignition system is up to snuff.
Car: '02 Z06
Engine: L33 5.7
only reason im asking these questions about hei..
http://members.optushome.com.au/iroc...5/325hp305.htm
they started with intake and hei.
so i wanna somewhat follow this lead up till the vortec which i wont imitate.
how much do gm hei's run?
anyone got a link?
anyone got a link?
Car: 88 Camaro SC
Engine: SFI'd 350
Your stock one will work fine unless your going over to a carb. In california, though, that will fly like a brick at inspection. Wont get very good results with all those mods to a stock tbi system. Would work fine with (lots of) tuning and might give you a chance at passing smog if they dont catch on to what youve done. Everything except the cam would be good mods to an L03 with tbi.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
yup.
and unless yours is broke, why replace it?
you get ZERO gain in power.
Zero gain in reliability.....
total waste of money.
there are guys running in the 9s (and possibly quicker) that use GM distribs.... no reason to swap other then to have somthing shiny and billet to point to.
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
If you are talking about the older style HEI for a carbed motor, just rebuild an old one. My base distributor is from a 78 skylark. I just cleaned it, replaced the electronic parts and custom set the advance curve. The distributor cost me 20 bucks!
amargari
Nov 10, 2015 02:09 PM
sreZ28
Oct 22, 2015 08:21 AM
86CamaroDan
Sep 29, 2015 10:08 PM
