Will an '88 TPI Vette distributer work on a '91 TPI roller motor?
Old Mar 25, 2001 | 08:08 PM
F-Messenger's Avatar
Just wanted to confirm. Thanks!
F-Messenger
Old Mar 26, 2001 | 05:43 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Should be no problem at all.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Mar 26, 2001 | 01:00 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes the distributor should work, but the Corvette has the coil in cap type, while the 91 f-body has the coil separate. I doubt it'll be a problem, but you might have to leave the plastic cover off.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 26, 2001 | 02:05 PM
88SS6SPEED's Avatar
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
What Kevin and Rob said is correct, the only monumental difference is if you have to change the distributor gear, the 87-up F-body distributors has a .491" diameter shaft and the Y-body 87-91 distributor has a .500" diameter shaft. The only way I found this out, was the time I tried to buy an F-body MELLONIZED OEM roller cam distributor gear, and the dealer didn't have one, so I asked for the 87-91 Corvette MELLONIZEDgear. When I tried to install it, it was too large for the .49" shaft. So I returned it, and just went to another dealer for the right gear. HTH's
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed/1-3/4" full length headers/3" X-PIPE assembly/ 8.5" G-80 rear with 3.73 gears.
http://community.webshots.com/user/ssynergy
www.y-t-g.com/88monte
Old Mar 26, 2001 | 04:40 PM
Hezuse! Thankyou for the update guys! Woah. Almost bought that vette dist. Good thing I didnt, gears wouldnt work - diff. diameters. Thanks again!
F-Messenger.
1992rs/ss
Jan 31, 2025 05:10 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Brcharrelson
Aug 26, 2015 07:47 PM
squiggy2
Aug 9, 2015 09:30 PM
