What is a 427?
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
What is a 427?
Is a 427 and a 454 just a 400 core stroked with different length rods & or crank?
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Theres a 427 big block (the true 427 designate) and a 427 small block (427 stroker motor).
The big block is a 4.25" bore x 3.76" stroke.
The small block is a 4.125" bore x 4.00" stroke.
doubt if it's really part of your question but ford also has a 427. chevy has two 427s, tall deck truck engines that are basically junk for preformance applications and the standard deck car engine.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Ford's 427 is not really a 427 though. Its a 425. And their 428, which actually is a 427, is the same bore/stroke as a 427 stroker small block chevy.
The tall deck big blocks (427s anyway) are good for racing use, but too expensive to build for the street, compared to a regular big block.
Originally posted by blacksheep-1
Don't forget the 429 Boss Ford, and the 427 SOHC Ford.
The Boss 429 is a Hemi
