ARP Rod Bolts
Old May 23, 2004 | 02:20 AM
JesasaurusRex's Avatar
ARP Rod Bolts
Sorry 4 this question in advance since if I didnt lose the paper I wouldnt be asking right now. Got some summit stage 1 connecting rods with arp bolts and the arp assembly lube, wanted to know what the torque specs were for the bolts with the assembly lube. Thx in advance guys.
Old May 23, 2004 | 02:28 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
http://www.arp-bolts.com/pages/tech/images/fasttorq.pdf
Old May 23, 2004 | 02:30 AM
What size are the rod bolts
Old May 23, 2004 | 02:54 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Uh i thought you knew the size
http://www.arp-bolts.com/pages/tech/images/rod_bolt.pdf
Using that chart, then crossreferencing the part numbers to engine size application, 50 ft-lbs is the number they say.
Old May 23, 2004 | 06:33 AM
ede's Avatar
ede
every arp rod bolt i evve used the instructions said to torque them and back them off twice before the finial torque or use a rod bolt gauge.
Old May 23, 2004 | 07:32 AM
84 Restore's Avatar
Car: 1984 Z28 camaro HO Gun metal Gray
Engine: 305,L69 H.O. rebuilt
man I love this site!
ede, I am glad u are on this site. I have read more important tips from u than in both of my manuals. I mean it. I would never have know to do the double torque on the rod bolts. I would have torqued them down double checked them and on to the next. I get over welmed when I think all of the things I have to remember.Thanks
Old May 23, 2004 | 07:40 AM
ede's Avatar
ede
well thanks but not sure all the praise is that well deserved. all the info i got came with the rod bolts or from arp web site. i'd believe them long before i would soem dumbass like me on the net. the torque two time thing is to prestreach the new rod bolts, doesn't really apply to stock bolts from gm.
Old May 23, 2004 | 10:12 AM
Thx, Summit says 60ft lbs with the lube so there ya go. Thanks guys and sorry again for the stupid thread.
Old May 24, 2004 | 06:24 PM
Found my paper, you are correct my fault 50lbs is correct, stupid summit racing. Thanks again, luckily didnt start the engine yet w00t :hail:
Old May 27, 2004 | 12:57 AM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
ok but if you go to the arp website they give this elaborate explanation of using a stretch guage to torque your rod bolts and then when youve done that they say to "resize" them. what the hell are they talking about and cant you use a micrometer to do the same thing? i don't see why you just cant use the arp bolts, prestretch them like ede said and then torque them to spec. any comments?
Old May 27, 2004 | 01:26 AM
Patrick007's Avatar
A strain guage is definitely the most accurate way of torqueing rod bolts. The idea behind any fastener is that as you 'tighten' it you're causing a normal stress within the bolt (and thus a force acting to hold the two parts together). Knowing the properties of the bolt material (ie modulus of elasticity) and it's cross sectional area, you can acheive this acting force by causing a strain in the bolt ( change in length divided by original length ). I could throw the formulas at you if you wish but basically ARP can determine the amount that the bolt needs to be stretched in order to achieve the necessary force to hold the rod cap on. Some people do not have access to a strain gauge however, thus most repair manuals and assembly instructions will give recommended rod bolt torque values. This is their approximation as to how much torque is generally required to achieve the necessary amount of bolt elongation. I would not trust this method for rod bolts however, as i've seen significant deviation from this approximation. Either go buy a strain guage or pay someone else to do it.
Patrick DeGrosse Jr.
Old May 27, 2004 | 03:01 AM
cormyr's Avatar
Engine: 383 miniram
good explanation but what do they mean by resizing them
Old May 27, 2004 | 03:55 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Basically, when you put in new bolts, the cap may seat differently than it did before. Due to the nature of the rod, it obviously needs to be perfectly round. Even the slightest thousandth of an offset can be bad. I believe resizing a rod means to make the big circle round again.
Old May 27, 2004 | 04:28 AM
ede's Avatar
ede
to resize a rod a small amount is removed from the syrface of the cap, making the hole out of round. the hole is them honed back to round and to spec. last set i had resized cost 80 dollars including pressing the pistons on.
Old May 15, 2015 | 06:34 PM
drag10's Avatar
Re: ARP Rod Bolts
Def not a stupid thread.no question is a stupid question. .arp website is acting crazy right now and I need the torque specs for the rod bolts..thanx to u starting this thread I now have my answer. .
Hotrodboba400
Dec 10, 2019 07:07 PM
billybob6110
Sep 23, 2015 01:30 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
