110mph to 145mph gauge question
Car: 89 Camaro RS
Engine: 305 TBI
Transmission: 700-R4
Right now my car has a 305tbi. Im going to be putting a 350tpi in it (probably with a mild cam and new or ported heads). my question is, can I put 145mph gauges in and still have accurate readings?
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
I just did this yesterday! And yes, it is a the most direct swap there every was or will be. I was even able to use my original odometer. If you want to do this, unscrew the 3 screws on the face plate of the original speedo and slowely take the odometer out with some needle-nose pliars. Do the same with the one from the 145 speedo and then just swap them out. But be very careful. I attempted to take apart my 115 speedo and do it that way, but I ended up completetly destroying it. It now makes a nice wall decoration.
If that wasnt clear, feel free to PM me tomorrow. I'm waaay to tired!
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The only problem you may have is people questioning the accuracy of the miles on your car. Otherwise it is plug and play. I had no idea that you could swap odometers like that. Now you can tell people you have the origonal odometer and replacment speedo.
Car: 2002 Formula Firebird
Transmission: 4l60e
I had a 145mph speedo in mine for awhile. Everything worked fine except the speedo. It was 10mph off but I think it just needed calibrated. The speedo always read 10mph even when I was stopped lol.
I'd like to get another 145 cluster but I think I will go ahead and get a convan classics cluster thing and full it with autometer sport comp gauges
Car: '90 RS
Engine: 377 LSX
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Mine was also off by 10 mph when I switched to a 140 speedo. My buddy pulled the needle off and replace at the 0 mph spot on the gauge. Now it is pretty close to correct
Transmission: 4l60e
I'm hoping some autometer gauges will make it more accurate. I got a autometer water and oil pressure guage already. Stock oil pressure gauge showed 40 at idle at cold startup...autometer shows 65psi...
Water temp on stock gauge was 160 degrees...autometer is showing a steady 182 degrees.
Car: 89 Camaro RS
Engine: 305 TBI
Thanx for the replies. I'll try this sway another time. My car is heating up WAY to fast ; think its the thermostat. So the gauges will have to wait. I'll probably get a 145mph cluster off ebay and some glow gauges from this one site.
Ghettobird52
Jul 5, 2024 11:18 PM
