uneven power at low rpm:s --> car shakes a bit
Old May 27, 2004 | 05:58 PM
Liquid_Metal's Avatar
Car: Red '89 GTA
Engine: TPI LB9
My car sort of shakes at low rpm:s. I have to be real precise with the gaspedal to keep this to a minimum. I'm sure I'm not doing anything wrong driving-wise(sharp driver ), and I don't belive it's supposed to be this difficult to keep the ride smooth. It doesn't always do this but often enough to be irritating.
I don't really have any idéa of what this could be... there's some blueish smelly smoke at startup, that's all I can think of.
...any help???
Old May 27, 2004 | 06:01 PM
ede's Avatar
ede
have you tried trouble shooting? made sure the tune up is good? scanned for codes?
Old May 27, 2004 | 07:11 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
As ede asked, is it throwing any codes? and whens the last time it had a full tune up?
Bluish smoke is an indication that you are burning oil. If it is only at startup, id suspect the valve seals have gone bad (common problem).
Old May 27, 2004 | 07:18 PM
Car: Red '89 GTA
Engine: TPI LB9
I'm not sure what you mean...? Troubleshooting on the internet or?? Where would I find such a thing if that's what you mean? What does tuneup mean? What codes?
...Sorry, I understood nothing of what you wrote! Guess my english aint that great. Hehe!
Old May 27, 2004 | 07:34 PM
Luder[PAK9]'s Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6 MPFI
Throwing codes = is the check engine light on?
Tune up = when's the last time you replaced the spark plugs, wires, and cap and rotor?
Old May 27, 2004 | 08:24 PM
Car: Red '89 GTA
Engine: TPI LB9
I was afraid it might be the valve seals and I read somewhere that if some(?) seals go you might get powerloss, so that's why I suspected that.
No it's not throwing any codes. The plugs have recently been replaced, but I just got the car so I'm not sure about the rest.
...Probably should take it for a tuneup.
thanx
Old May 28, 2004 | 04:42 AM
ede's Avatar
ede
trouble shooting is a systematic logical search to finding a problem. for example no start condition logical thing would be to check for spark.
tune up is the replacing of parts, like plugs and wires, as well as adjustments, like timing.
codes are the stored trouble coeds in the ecm. you can do a search here and find out how to do it and pics, alos there should be some info on the main page.
Old May 28, 2004 | 08:04 AM
Keith_Indy's Avatar
Car: 87 Firebird Formula
Engine: 305 LG4
I would check your engine mounts and transmission mount. That could cause some shaking if they're not in good shape.
jaridjohn
Jul 8, 2024 03:49 PM
customblackbird
Aug 15, 2021 10:16 PM
kah992
Aug 19, 2015 02:55 PM
novaderrik
Aug 10, 2015 12:44 PM
