What type of heads?
Old May 29, 2004 | 10:03 AM
iroc-ice's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Transmission: 700-R4
What type of heads?
I bought a 350 tbi or carb (can't remember which one) from a 91 van to put in my camaro. Does anyone know what kind of heads came with this engine?
Old May 29, 2004 | 11:52 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
are you asking which heads you have on the engine? or which heads would have came on that engine? if you have the heads on the engine or with it then pull a valve cover off and read the casting numbers in there then post them so we can decode what they are
Old May 29, 2004 | 12:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It will almost certainly be a TBI motor, with sworl-port heads.
But you have it sitting in front of you, look at the casting numbers, they tell all.
Old May 29, 2004 | 12:20 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Once you get the casting number, take them to www.Mortec.com and look them up. Casting number 14102193 is the 350 TBI "swirl port" design.
Old May 29, 2004 | 09:56 PM
iroc-ice's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
The motors sitting at the junkyard right now. But I'll tell you the number when I go pick it up. And what is "Swirl port"?
Old May 29, 2004 | 10:03 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
A swirl port is a casting design used by chevy to more or less swirl the incoming air charge. Its great for fuel economy and looow end torque. Anything above 3000 or so RPM and its nothing more than a flow impediment.
They arent a BAD head....if your a 4x4 guy. For anything resembling performance on the street, they should be avoided. I hear they make good boat anchors. I think im gonna try that with my practice 187 head.
Old May 29, 2004 | 10:30 PM
iroc-ice's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Sounds like there junk then. I'll just keep my original plan of replacing them with l98 heads. I'll practice porting on them if they are swirl ports.
Old May 30, 2004 | 08:38 AM
SOLID LIFTER's Avatar
Car: '87 Mustang LX
Engine: 5.0
Swirl ports.
Old Jun 12, 2004 | 12:12 AM
badone07's Avatar
My Swirl Ports...
colton_carlson
Mar 8, 2019 12:21 PM
z28guy134
Sep 1, 2015 11:50 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
bdads
Aug 24, 2015 06:01 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
