Timing Problem
Old May 30, 2004 | 02:14 PM
Korn1699's Avatar
Timing Problem
I have an 87 Camaro with a 305 and 4brl carb. I can't seem to find any label that states the timing, and every book I can find says to check the label. Does anyone know what the timing adjustment is for that?
Old May 30, 2004 | 03:39 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Probably a base time of 6-8 degrees before TDC should work. If you havnt already looked there, the labels are on the underside of the hood.
Old May 30, 2004 | 07:02 PM
ede's Avatar
ede
i'm thinking a 305 carbed engine was 0 but i might be wrong. setting it to 6 or so wouldn't be bad, actualyl maybe even better than 0
Old May 30, 2004 | 09:10 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
The sticker on my radiator shroud says 6*@700rpm. That is for a '82 LG4.(305 4bbl)
Old Jun 1, 2004 | 06:16 PM
Korn1699's Avatar
thanks, now the only problem is that the repair book I have said something about separating a wire before doing that and connecting it after. I have no idea where it is. The book had a picture, but it didn't seem to help.
Old Jun 2, 2004 | 10:17 PM
simpleman's Avatar
Car: 89, 91 & 92 RS's
Engine: 305's & 335 Stroker
Transmission: All 700 R4's
Timing Problem
My Chiltons shows 6 degrees BTDC for both VIN H & F on the 87 305. Idle for VIN H is 700 RPM if you have the manual trans & 500 for the auto, VIN F is 500 RPM for either. The wire they are speaking of is a brown with white stripe hanging out of the harness back by the blower motor on the passenger side. Just unplug the connector while setting the timing & reconnect it when finished. It also states that for all feedback carb systems to disconnect the 4 wire connector at the distributor.
Good Luck,
Simpleman
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
