new 305 with 100 miles on it....runs hot
Old May 30, 2004 | 04:21 PM
ibwats's Avatar
Car: 1989 RS
Engine: 305 LO3
Transmission: auto
took my freshly remanufactured 305 z28 out for a drive today and to try and break her in.....everything in my car was replaced from the radiator to the rear end.....my question is on the way back with the air on of course it was creepin to 230 degrees
or so....turned air off and still kept cliiming.. is it running hot cause the new engine is still tight....just wondering..thanks for the help
Old May 30, 2004 | 05:35 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
do you have electric fans on it or a belt ran fan? ....it shouldnt run hot even being brand new ...it should run normal
Old May 30, 2004 | 07:49 PM
ibwats's Avatar
Car: 1989 RS
Engine: 305 LO3
Transmission: auto
has stock electric fan......runs at 195 - 210 without ac....and the motor has that water thin break in oil......and not to mention white smoke at idle...???
Old May 30, 2004 | 07:50 PM
ljnowell's Avatar
Sometimes a new engine will run a little hotter, but it shouldnt be overheating, if that makes any sense.
Old May 30, 2004 | 07:51 PM
ljnowell's Avatar
damn, just saw that white smoke at idle thing, sounds like you are burning coolant. Check for headgaskets leaking, or something along those lines.
Old May 30, 2004 | 09:24 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yep, white/grayish smoke indicates that coolant is getting in to the combustion chamber. Do a compression or leak down test on all 8 and get an indication of whats going on.
Old May 31, 2004 | 12:46 AM
ibwats's Avatar
Car: 1989 RS
Engine: 305 LO3
Transmission: auto
ok i have been reading and this is what i hope it is.......i hope the smoke is blue and
the rings are just not set in yet....and it has been bored .30 over so thats why it runs warmer......to be continued will let u know....
thanks for all the replies after spending all this money to revive my z28 we all want it perfect...right...lol
Old May 31, 2004 | 05:32 AM
contactpatch's Avatar
Engine: sbc 350
My generic advice, in these situations, is to
take the thermostat out, run the car a few minutes,
and tell the forum what happened.
There is no reason for overheating, in this matter.
contact
Old May 31, 2004 | 05:42 AM
ede's Avatar
ede
i'd double check for leaks, timing, and A/F mixture. besides the compression test you might want to look for combustion gas in the coolent.
Old May 31, 2004 | 01:27 PM
ibwats's Avatar
Car: 1989 RS
Engine: 305 LO3
Transmission: auto
replaced radiator cap and doesnt overheat now.........but still blue smoke at idle...? is that break in oil they use the way to go or not??
colton_carlson
Mar 8, 2019 12:21 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
mdtoren
Aug 16, 2015 05:45 PM
3rdgenparts
Aug 6, 2015 09:03 AM
