my damn car won't start
Old Mar 27, 2001 | 09:31 PM
1985-Z28's Avatar
Hey all-
My damn Z wont start. I have replaced the ignition coil, the cap, the rotor, and now the ignition module. What else is left? It's getting all kinds of gas, all kinds of spark, and it doesnt start. Just wanted to see what you guys thought about it. Thanks
Old Mar 27, 2001 | 09:50 PM
mtx28's Avatar
timing right? could be far enough off so it wont start.
Old Mar 28, 2001 | 01:46 AM
Omar's Avatar
Is it actually cranking, or just doing nothing? Just wanting to clarify....
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Mar 28, 2001 | 11:25 AM
1985-Z28's Avatar
It is actually cranking. Spark, gas, and everything. No start though.
Old Mar 28, 2001 | 11:28 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What do the spark plugs look like?
ICON Motorsports
Old Mar 28, 2001 | 12:35 PM
SUPER-SPORT-CHEVY's Avatar
Most likely the spark plugs are wet. replace them with new ones see if that works. Cause it sounds like you flooded it
Old Mar 28, 2001 | 02:41 PM
1985-Z28's Avatar
I dont think its flooded, cause the plugs arent really wet or anything. its been sitting for a couple days, so i dont think there would be a problem with flooding.
Old Mar 28, 2001 | 07:18 PM
Stuart S's Avatar
On my 86 IROC (carbed) the needle and seat was sticking on the Q-jet and causing the carb to dump in way too much fuel...thus fouling out the plugs ASAP and the excess was burning thru the cat and glowing red..
I got a rebuilt Q-jet and it runs like a champ
Old Mar 28, 2001 | 09:01 PM
Matt84TA
Guest
Posts: n/a
If you're SURE you have fuel and you're SURE you have spark, it can only be timing. Check your distrib, might be loose. It's happened to me before
Also, check your plugs. If they're soaking wet you're flooding. If they're really oily you'll have a hard time starting as well.
Do you get a cough or any attempt to start?
Is this a carb car or TPI?
Old Mar 28, 2001 | 10:59 PM
BigChevy342's Avatar
Or check for a wire disconnected on the coil, or just look around fro diconnected wires, one of the wires of my coil came loose and it woldnt start
Old Mar 30, 2001 | 12:03 AM
1985-Z28's Avatar
I checked the timing and its right on. It doesnt really seem like the plugs are too oily, or like the engine is flooding. It is a carb engine. Still trying to figure out whats going on. Thanks
Old Mar 30, 2001 | 12:17 AM
zroc's Avatar
Car: 87 IROC
Engine: LB9 for the moment
pull the coil out of th top of the cap and check for a crack... or a bad ground or something... is there anything that led up to this???
zroc
Old Mar 30, 2001 | 05:55 PM
1985-Z28's Avatar
Nothing led up to this, just one day it didnt want to start. The coil is new and i know all the grounds are made.
Old Mar 30, 2001 | 06:23 PM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
timing chain? look in the oil filler while having someone crank it. valves moving?
Old Mar 30, 2001 | 08:05 PM
Stuart S's Avatar
I'm tellin ya - carb !
Check the archives for my posts about 3-4 months ago about my LG4 86 IROC...
I tried EVERYTHING, like you have - it was carb...didn't make logical sense, but that's was it..
Look into it...
My AIM is "TransAm87WS6", or you can e-mail me if you want more info...
[This message has been edited by Stuart S (edited March 30, 2001).]
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
