motor mounts
Old Mar 27, 2001 | 04:27 PM
buddman91rs's Avatar
motor mounts
is there anything special to changing them? im going to change within the next couple of days so i need to know kinda qiuck-like...thanx in advance
1991 RS LO3
mods: 14" chrome air cleaner, straight-piped after cat exhaust with one chrome dual tip on the left side.
future mods: headers, removing smog equipment, and as many cheap mods as i can find
aol s/n: budman8503
GONE MUSTANG HUNTING.......
BACK IN 10 SECONDS
Old Mar 27, 2001 | 08:09 PM
Andy89RS's Avatar
Yeah: small hands. This WILL take more time than you think. The nuts inside the crossmember are not held in place, so you'll have to figure out how to get a wrech into that tiny space and hold them. A few years ago I had one go bad, so I figured I'd replace both while I was at it. I replaced the bad one. The other mount is still in the box.
Old Mar 27, 2001 | 09:55 PM
bad camaro RS's Avatar
have fun!!!!! i jus replaced mine with poloyurathane it helps to have 2 people and a few extentions and knukles they are a pain when i put em back on i put nuts on top side i did mine with motor out i hate to do em with motor in good luck later
1992 camaro RS w/ 350tpi
195cc AFR heads with compition port work milled to 58cc
1 3/4 hooker long tube headers
4" mufflex system
custom ED Wright chip
eddelbroc intake base and runners and much more
new best ET 13.5 @104.66 on stock heads
no times with new afr heads hoping for 12's on motor
http://www.nav.to/badass355tpi
Old Mar 28, 2001 | 02:57 PM
oh they're bolts holding it to the crossmember..... i thought they would be like screws...oh well i do have samll hands cause im only 15 im thinking it wont take that long.....i replaced plugs, wires,rotor,cap, and fuel filter in a couple of hours and still had time for a test run afterwards..... thanx guys
1991 RS LO3
aol s/n: budman8503
BACK IN 10 SECONDS
Old Mar 28, 2001 | 03:02 PM
rezinn's Avatar
I need to change mine too... I haven't gotten down to it though. How long will this take? How exactly do you change the mounts? I would think there would be some engine movement, hope not =p
Old Mar 28, 2001 | 05:24 PM
scauffiel's Avatar
I just did mine this past weekend. With the engine out of the car, it took about an hour to remove them and another hour to get them back in. Get a flexible shaft mounted magnet because you're going to need it when you drop the bolts/nuts inside the frame. And eventually you will drop one of them inside the frame.
You believe the dealer wanted $75 each for them? Got them at Advance for $8 a piece. What a ripoff...
Steve
Steve's Trans Am Temple
Old Mar 28, 2001 | 05:36 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
I just did mine a couple weeks ago with the engine out of the car. I was able to change them out in about an hour and a half. Once you get the proper "custom" tool and a techique, it goes pretty quick I would not want to try and change them with the motor still in the car however!
Old Mar 28, 2001 | 07:05 PM
merf23's Avatar
I found it easiest to compress the springs, disconnect the ball joint and let the control arms hang down. The time it took to drop the control arms saved a lot of aggrevation.
1984 Z28 (L69) monochrome tangerine orange with IROC decals and hood
1987 IROC wheels with Goodyear GSC's
305 from 87 IROC with 1994 LT1 cam (203/208 .450/.460")
performer intake with holley 600 (#1850)
Qjet is in the works
dynomax cat-back
non WC T-5 with 0.73 5th
3.27 nine-bolt
Old Mar 28, 2001 | 09:04 PM
Matt84TA
Guest
Posts: n/a
huh? These were never a problem for me?
But yeah get a telescoping magnet for dropped bolts. Should be mandatory equipment anyway for working on cars
Old Mar 29, 2001 | 07:31 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
I got mine by holding a wrench at varying angles with a pair of vise grips. Stuff rags in the crossmember... Drop the nut in there and you'll spend more time trying to fish them out with a magnet. (you'll drop it... about 100x)
Use some contact cement or bubble gum on the end of the wrench to hold the nut.
Old Mar 29, 2001 | 03:34 PM
mine were 9.99 bucks a peice at the local discount auto parts store
1991 RS LO3
aol s/n: budman8503
BACK IN 10 SECONDS
Old Mar 30, 2001 | 09:41 PM
rezinn's Avatar
Anyone have the part number for polyurethane motor mounts for a third gen small block? Trans mount too.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
