Sensor coming out of radiator??? TPI engine
Old Jun 5, 2004 | 10:41 PM
TPI86TA's Avatar
Car: 88 GTA
I have an 88 GTA Trans Am with an automatic 350 TPI. I noticed on the passengers side of my radiator it looks like there is a sensor or something plugged into it. It looks like maybe a wire used to go to it,but i cant find it. The sensor thingy has what looks like blade or male type connector for something like a female connector. Anyone have any clue what this thing coming out of the radiator is,and should it be hooked up....Thanks...Al in NJ
Old Jun 6, 2004 | 12:16 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
That is a replacement radiator (maybe a modine or something) and that sensor is used on some applications, but not ours.. I believe it is a coolant level sensor. No worries, I have one too (disconnected).
Old Nov 5, 2004 | 09:59 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
My 88 GTA has that too. Is the coolant level sensor & if is not pluged in you will get a low colant reading on you dash. Look around, the cable should be somewere around. Do you have a digital dash? Because mine is digital & there is a little diagnostic window on my dash (the one that reads "PONTIAC" when every thing is fine) When I changed my radiator the first time I didnt know about the sensor & the radiator that I got didnt have the conection for it. So all the time that I had that radiator, the diagnostic window had a "low coolant" reading.
Old Nov 5, 2004 | 10:06 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That is a coolant low level sensor that was used in some of the earlier model third gens and other GM vehicles. On the later cars that sensor was removed and a brass plug was installed in its place. On my 89 Iroc, there is a idiot light next to the parking brake light for that function. Since the sensor is not used on my car the light is non-functional even though there is a new bulb in it.
Wade787b
Sep 29, 2015 01:15 PM
The_Phoenix
Sep 3, 2015 10:56 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
squiggy2
Aug 9, 2015 09:30 PM
