has no one put an external electric on their cars?
Old Jun 6, 2004 | 02:03 AM
treeohfive's Avatar
i ask this because i posted twice about doing it and no one has responded.
im sure some of the carb people have done it...im not sure if tpi/tbi needs *speciial* pumps that produce a higher psi or what..
im carbed so im gonna give it a shot.....anyone know of a strainer type deal thall fit on 3/8 hose? i plan on just taking the in tank pump out and replacing the length that the pump takes up with 3/8 fuel line/hose.
Old Jun 6, 2004 | 08:35 AM
ede's Avatar
ede
lot of people have. for carb i'd run mechanical, if i could. if you run external eletric you don't need to do anything to the intank pump, it should pull fuel through it.
Old Jun 6, 2004 | 04:41 PM
treeohfive's Avatar
lol...seriously??? it wont slow the flow down?? thats crazy. if i didnt have ahole in my tank....id just do that then
Old Jun 6, 2004 | 04:53 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
with an electric and a carb you're going to need a regulator to cut down the pressure anyways. So it won't hurt it.
Old Jun 6, 2004 | 05:01 PM
treeohfive's Avatar
way ahead of ya....if i run a carb as it is now with the stock pump id have to have a afpr ive had one for awhile....mallory....3 port design.
also, this is a roller engine......id love nothing more than to run a mechanical BUT did the LT1 cam have a fuel pump lobe? i wasnt paying too much attention to this factor when i put the cam in due to me not caring at the time if it had the lobes or not
Old Jun 6, 2004 | 05:44 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Don't know for certain but the LT4 hot cam did, so I would assume the LT1 would
Old Jun 7, 2004 | 08:49 AM
treeohfive's Avatar
hmm....do i need a special type of lifter for the mechanical fuel pump to run on a roller cam? do they make a roller lifter for the mechanical pump?? i dont know much about mechanical pumps....never ran one....well....i never put one on a roller engine more like
Old Jun 7, 2004 | 10:32 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Some people claim that they successfully pull through the stock intank pump but I didnt have much luck. It would suck through it but the pump was working really hard trying to keep up. It made this really weird inconsistent buzz like it wanted to die. BIiZzzzzzzzz--BURRRR-BIZZZZZZZZZZ-----BIRRRZZZZ. I pulled the tank and replaced the pump with rubber fuel line. Now my pump makes a nice steady and much quieter BURRRRRRRRRR noise.
I prefer electric pumps over mechanical but I will say most mechanical pumps are much less likely to fail compared to most aftermarket electrics.
Old Jun 7, 2004 | 11:09 AM
treeohfive's Avatar
yeah, i just wouldnt bother to try to pull the fuel thru the stock pump with an external pump... just doesnt seem efficiant....i mean most people go and buy a 110 or 140 gph pump and try to pull the fuel thru a pump in the tank?? wtf.....the pump in the tank flows at what...200 liter per hour? thats like 55 gallons per hour......even if it does work....is the area large enough to flow the true 110 - 140 gph? or would you basicly get the power of the 110-140 but you get 60 gph in reality pulling through the pump?
in any event, it sounds like a lazy mans way to be half assed.
im pulling the pump out the tank.....all there is to it.....
and no im not hacking up the back of my car and cutting holes in it to do so......ive come way too far to just do that crap.
here is a good question......what fuel filters will allow a 110-140 gph flow? i doubt the stock filter will.
Old Jun 7, 2004 | 11:22 AM
Car: '89 IROC-Z
Russel and Aeromotive make nice straight-thru fuel filters that will handle more than your factory 3/8" fuel lines could ever imagine flowing through them. Be sure to mount the filter BEFORE the pump.
Old Jun 7, 2004 | 11:31 AM
treeohfive's Avatar
have a part # and a site which i can order from?
Old Jun 7, 2004 | 01:39 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
No special rod, just a standard fuel pump drive, actually avalible at 90% of all parts stores. In my dads truck it actaully was a TBI 4.3L that someone converted to a carbed 350 years before he bought it. Once in a while it would vapor lock for no real reason. The fuel tanks started to rot away so we replaced them. When we pulled the tanks down the intank pumps were still there. So Id say pulling fuel through most in tank pumps works, but if you have a higher PSI pump like a TPI it may not pull through it very well.
www.jegs.com/ has all the components you would need just go there and do a quick search.
BRoss99
Aug 10, 2025 05:08 PM
MustangBeater20
Oct 29, 2022 09:20 PM
86IROC112
Aug 17, 2015 02:00 PM
mizz0313
Aug 12, 2015 06:45 AM
L98GTA87
Aug 5, 2015 11:02 PM
