Is this belt wheel supposed to turn???????
Old Jun 6, 2004 | 09:00 AM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
the one with a arrow pointing to it. wont turn by hand
its a serpentine belt system.
Old Jun 6, 2004 | 09:05 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
You should be able to turn that by hand. Thats your air pump. The unlabeled pully on the right of the picture is your power steering pump.
Old Jun 6, 2004 | 06:09 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
it also could be the belt tensioner.. hard to tell by the pic.. does the pulley have a pump with some wires and tubes attached to the backside of it?
Old Jun 6, 2004 | 06:11 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
All pulleys are supposed to turn freely by hand. The belt tensionor is up top, between the A/C and the water pump in that picture. Sounds like your air pump has seized up. Mine did that a few months ago, and to make matters worse, I locked my keys in my car too.
Old Jun 6, 2004 | 06:14 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
yup, AIR pump
Old Jun 6, 2004 | 11:28 PM
Borsty's Avatar
Car: 89 Trans am
yea its air pump 45$ replacement, thanks guys!
Old Jun 7, 2004 | 12:14 AM
sorch60's Avatar
The easiest way to fix a smog pump with a seized pulley is to remove the belt and forget about it.
Old Jun 7, 2004 | 03:22 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
On a serpentine setup, remove the belt....brilliant idea. I like the idea of having no water pump or alternator or power steering, either.
Old Jun 7, 2004 | 03:40 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
I'm not big on serpentine systems, so don't flame me, if you can't, but can't he just remove the smog pump and get a corispondingly shorter belt, I'm sure someone has got the proper legnth someware?
Old Jun 7, 2004 | 12:00 PM
Car: 1987 Trans Am
Engine: tree-fiddy
https://www.thirdgen.org/newdesign/t...rpentine.shtml
Old Jun 7, 2004 | 03:42 PM
sorch60's Avatar
My bad, didn't read that part. Anyway, if its not a TPI car remove the smog pump and forget about it or if it will work get a shorter belt that will bypass the smog pump. If it is a TPI car then replace the pump.
eightsixseven
Dec 16, 2024 01:50 PM
Fronzizzle
Mar 18, 2019 08:29 PM
novaderrik
Aug 10, 2015 12:44 PM
BrianI
Aug 9, 2015 11:52 AM
