My car just deiseled for about a minute...wtf?
Old Mar 30, 2001 | 11:47 AM
RS'er's Avatar
It deiseled for about a minute,then the next time I started it up,it turned right off. Whats up?
Old Mar 30, 2001 | 12:30 PM
ede's Avatar
ede
check the timing, plugs, run higher octane fuel
ICON Motorsports
1st & 3rd
Old Mar 30, 2001 | 03:37 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Also, perhaps minimum idle?
Old Apr 1, 2001 | 06:28 PM
Cosmik Debris's Avatar
You could also have some carbon build up in your motor.
Cosmik Debris
Old Apr 1, 2001 | 10:06 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
WHat engine? If you have a fuel-injected engine, you probably have a leaky injector, to be able to get fuel to let it run-on like that. If you have a carbureted car, then check your timing, idle speed, tune-up, etc....
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Old Apr 2, 2001 | 12:15 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
make sure you dont have the diesel 305 option with extra torque package, or maybe put diesel fuel in by accident.
Sorry, I'm an idiot
Old Apr 2, 2001 | 07:06 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
If you added an aftermarket cd ignition, install a diode in the alternator 'exite' wire to block reverse leakback keeping the ignition from shutting off.
Old Apr 2, 2001 | 10:13 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
LMAO, yo ubeat my record - the longest my car ever dieseled was about 20 secs... :P Try running a higher octane fuel.
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
Clarion 45X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
"A four cylinder is only half an engine"
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
