effects of having roller rockers to tight bad?
Old Apr 2, 2001 | 02:20 PM
bad camaro RS's Avatar
jus checking i have a 87 350 roller motor how can i tell if theyre to tight?
1992 camaro RS w/ 350tpi
195cc AFR heads with compition port work milled to 58cc
1 3/4 hooker long tube headers
4" mufflex system
custom ED Wright chip
eddelbroc intake base and runners and much more
new best ET 13.5 @104.66 on stock heads
no times with new afr heads hoping for 12's on motor
http://www.nav.to/badass355tpi
Old Apr 2, 2001 | 03:02 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
At the risk of sounding like Dad, what makes you think they might be too tight?
If an intake is too tight, it will run real rough and may even spit back through the intake because when that cylinder fires, part of the charge will escape back into the intake, and may even set the intake charge off. If an exhaust is too tight you'll have a weird little "fsst-fsst-fsst" kind of noise in the exhaust like an exhaust leak, and it will burn the exhaust valve rapidly.
ICON Motorsports
Old Apr 2, 2001 | 04:02 PM
Bort62's Avatar
just to Clairfy, Loosen till it starts tapping, and then 1/4 turn More ?
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Apr 2, 2001 | 04:35 PM
Box of Rocks's Avatar
Uh,
Just to clarify......loosen it until you hear TAP..TAP...TAP, then TIGHTEN it 1/2 turn.
Too tight = rough idle, bent pushrods, possible catastrophic engine failure.
BOR
Old Apr 2, 2001 | 05:20 PM
it idles good i jus notice i had kinda of a miss at 5000rpm and i dont thenk its my 6al
Old Apr 2, 2001 | 05:26 PM
Macgyver's Avatar
Actually, loosen until you hear the tapping, then tighten to the point the tapping stops, then 1/4 - 1/2 turn tighter.
Old Apr 2, 2001 | 05:28 PM
Macgyver's Avatar
Oh, and if they are too tight, what RB said is correct, but you'll also notice that the engine doesn't want to rev as fast as it should.
Old Apr 2, 2001 | 05:29 PM
ede's Avatar
ede
without knowing more, and trying to not sound like dad, i'd guess maybe you valve springs are weak and not allowing your valves to really close, or bad part in the ignition, plug, wire, things like that. maybe even you're at the upper limit of your power band and it isn't going to do more.
ICON Motorsports
1st & 3rd
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
