Which Would Give More Power?
Old Jun 8, 2004 | 02:07 PM
88 Formula 355's Avatar
Car: 1991 Z28 Camaro
Engine: 355 Solid Roller
Transmission: Turbo 400
When I bought my car the motor was completely rebuilt bad *** from the bottom up but I dont know how much of a fan of the T.P.I, I keep seeming to have problems with starting and stupid stuff and it seems like the motor starves out after a certain rpm, a buddy of mine said he would trade me his edelbrock performer intake and 750 edelbrock carb and hei for my setup and give me $200.00. I'm thinking I'm gonna go ahead and do it, i think that the carb will give it a lot more power becuase the injectors and throttle body are completely stock the only thing that has been changed are the runners. Just wanting your opinions....
Old Jun 8, 2004 | 02:16 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
The TPI and performer will both kill horsepower. The performer is a stock replacement manifold, not a performance piece. The TPI stop making power alittle after 4000rpm. Not good for hp but pretty good a making torque. You car will be slow with either of them.
Old Jun 8, 2004 | 11:06 PM
what would be a good intake/carb setup then?
Old Jun 8, 2004 | 11:14 PM
StealthElephant's Avatar
Car: 87' Iroc
Stealth Ram or Accel Superram are possibilities.
HLY-7540P is Summit Part# for the Stealth Ram.
Old Jun 9, 2004 | 02:05 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
If your going to go carb I would get a 750cfm vacuum secondary holley (if you have a bit of power) and a edelbrock rpm performer air gap intake.
Old Jun 9, 2004 | 12:21 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Edelbrock performer RPM and RPM air-gap are excellent manifolds. The air-gap make more power then a Victor JR. all the way up to 5500 rpm or something close to that.
Fuel injection costs 10 times the price of a carb setup. It would be nice to have a good fuel injection setup, but its not worth it.
Old Jun 9, 2004 | 12:42 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
*couch* LT1 Intake *Cough*
Haha, just messing, although its still a cheap alternative if your into fabricating yourself. Rather than spend $1000+ for a holley or stealth ram, you can spend $400 or get your own intake and do it yourself for about $175. You'll see noticable gains, the car won't be as torquey down low, but you'll feel a lot more power up top. Just something to think about if you decide against going carb. www.lt1intake.com for info.
Old Jun 9, 2004 | 08:07 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Yeah but then you have to buy all the sensors, MAP or MAF, O2, and a bunch of others. Also you have to buy expensive fuel injectors, fuel pump,and ....
jhawkeye
May 25, 2022 06:33 PM
sailtexas186548
Aug 24, 2015 10:11 PM
mdtoren
Aug 23, 2015 12:52 PM
InfinityShade
Aug 22, 2015 08:00 PM
mdtoren
Aug 16, 2015 05:45 PM
