Trip odometer stuck
Old Mar 30, 2001 | 10:40 AM
JoeIROC's Avatar
Trip odometer stuck
My trip odometer is suck at 000.0! It was giving problems before it stopped working. For instance, the numbers would not move in sequence. Has anyone had this problem? If so, how'd you fix it? I'm afraid to mess with the odometer, which is working fine. However, I would like to get that trip odometer working.
Joe
86 IROC TPI 305
700-R4
K&N Air filters
Next mod = trans-go shift kit (level 1)
Old Mar 30, 2001 | 11:35 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Welcome to GM trip meters. They break alot. I'd guess probably fewer than 20% of all the ones more than 12 years old still work.
I know of no way to fix it, short of replacing it. However if you do that, get a 145 MPH speedo, and spend your trip meter replacement money on one of those (the trip meter is different) rather than on the 85 MPH one if that's what you've got.
ICON Motorsports
Old Mar 30, 2001 | 12:43 PM
JoeIROC's Avatar
I have the 145 MPH speedo. Sh*t!
I just wanted to know if (by taking out the pod) it could be fiddled with to get it to work.
Joe
86 IROC TPI 305
700-R4
K&N Air filters
Old Mar 30, 2001 | 01:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I have one 85 and 2 145s; the only one with a working trip meter is one of the 145s. The 85 and the 145 versions are exactly the same except just different enough not to interchange.
Maybe you can buy one at the dealer, or from a speedo repair place, I don't know. Good luck!
ICON Motorsports
Old Mar 30, 2001 | 04:12 PM
Timmys88Z's Avatar
Mine doesnt work anymore either!
It worked fine for like a year then one day I look down at it and the numbers are all going every which way! They spin all different ways all weird.
I'd like to fix it if possible but looks like I'll be buying a new speedo eh?
Old Mar 30, 2001 | 05:41 PM
JoeIROC's Avatar
Yeah, mine did do the same thing until it just stopped turning altogether. I figure it has something to do with a spring or catch pawl that isn't catching. I wonder if it could just be hooked back into place?
On another related story, I'd like to buy one of those all digital dashboards. I wonder if you have to start the odometer at 00000.0 though... If you did, I wouldnt want to do the swap.
Joe
86 IROC TPI 305
700-R4
K&N Air filters
Old Mar 30, 2001 | 06:30 PM
Chvywolf's Avatar
Car: Formula
Engine: Pontiac 400
Axle/Gears: 4.10
Mines following the group also with the stock 115mph. Oh well guess it's time for the 145... oh crap, i can't do that, my top would fly off, WOAH there it goes. HEhehe
"Oh yeah. well i'm taller"
89 RS Conv 305 700R4
85HO heads
Edelbrock intake
Holley 600
Hedman Hedders and Y pipe
Flowmaster
B&M MegaShifter
Old Mar 31, 2001 | 09:08 AM
TRVLIN99's Avatar
My 86' Iroc with a 145 speedo also has a bad tripmeter. I just can't see spending the 225.00 for the new assembly right now.
Old Mar 31, 2001 | 11:21 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
There is a way to fix it. I asked this question once and Vader knew how to fix it, I didn't do it, but if he explained it again I might want to.
Looking For:
87 IROC-Z28 350 TPI
The car I want.
84 TRANS AM 305 H.O.
Another car that would be OK to own while I still look for the IROC-Z!!
Old Mar 31, 2001 | 01:35 PM
IROCketZ28's Avatar
Not anything of great importance, but you can add my IROC to the list of screwed-up trip-meters. Mine still spins, but the 1st two numbers seem stuck together. At least I'm getting some of the best gas milage of any internal combustion engine I've runs across so far (if I were to believe my tripometer), a whopping 886 miles to one tank!!!
'87 IROC Z28
TPI 305
5-speed
3 1/2" exhaust w/ Flowmaster
Clarion, Kenwood, Eclipse, Polk, MTX, Autotek 1600 watt stereo system
Grant wheel
Old Apr 2, 2001 | 10:41 PM
Administrator
VADER!!!!!!!!
Looking For:
87 IROC-Z28 350 TPI
The car I want.
Old Apr 3, 2001 | 03:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I saw his post after I gave up on mine. The problem is that the entire mechanism is held against the drive gear by two small plastic "hooks". The hooks break at the attach point, then no more trip OD. I tried re-gluing mine, no go.
His fix is to remove the broken hooks, drill a very small hole where they mount, and epoxy in a piece of paperclip bent into the shape of the original plastic hook. There is one on each side. I haven't done it, but it sounds like the right approach. Just watchmaker-type detail work.
My '90 Bonneville SSE w/120k miles trip odometer works fine. It's almost 12 years old. Same for '91 Bonneville with about same mileage. Not all GM trip odometers are made cheap - but ours sure are.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, TBD heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
David Frans
Oct 31, 2015 08:12 PM
tmellott89
Oct 14, 2015 02:06 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
PestilenceIV
Sep 22, 2015 07:39 PM
ctoledo0834
Sep 18, 2015 04:16 PM
