Which Bosch Spark Plug
Old Jun 12, 2004 | 06:38 AM
<<K-O>>'s Avatar
Car: 88 TransAM GTA
Engine: 305 LB9
Axle/Gears: Stock
Hi,
I checked the old messages however I couldn't find any message specifically about my problem.
My engine is currently stock (i have a cold air intake and full exhaust without cat)
I'm going to replace my spark plugs. Bosch plugs are only ones I'm able to buy for the moment. However I couldn't decide which type to buy.
What is the meaning of +4s , +5s etc. ?
Which one would be the most suitable for my engine?
Old Jun 12, 2004 | 08:21 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Which Bosch Spark Plug
Originally posted by <<K-O>>
Hi,
Neither. Get the plain jain AC delcos. You will be much happier when they last more than a few thousand miles. If you must get Bosch stick with the single elctrode ones. No need to spend lots of money on plugs that are not a good match for our HEI's.
Old Jun 12, 2004 | 09:28 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Get the regular Bosch, or the platinum Bosch. Both should be single electrode. The regular Bosch plugs are as good as the AC delco ones, but because of the past debates on this board, when anyone hears Bosch, they immediately think of the Platinums.
The platinums are very good if you want to leave them in there for 100,000 miles (yes they actually can, though I wouldn't).
The problem is that if you put an aftermarket ignition in the car, you then can not use the platinums as there is too much resistance introduced into the system. HTH.
Old Jun 12, 2004 | 10:20 AM
Vader's Avatar
Which Bosch Spark Plug? Bosch plugs are only ones I'm able to buy for the moment. However I couldn't decide which type to buy.
The ones that say "Champion" on them. If you've waited a day to get an answer, you probably could have found decent plugs by now, and would not be stuck buying the Bosch parts.
Old Jun 12, 2004 | 01:11 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
You could also save a good chunk of change as the +4s are damn near $6 and standard Delcos are .99c.
And the +4 simply means that there are 4 ground straps in relation to the electrode. +2 means that there are 2 ground straps.
Old Jun 12, 2004 | 01:51 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
The basic bosch platinums will be fine if you have to. They will not work if you are using an MSD box or other product for your ignition.
Old Jun 12, 2004 | 02:33 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The only thing I dont like about the bosch platinum single electrode ones is the damn screw on terminals. They always back off and cause big problems. Other then that theyre a good long life plug for a stock or near stock application.
Old Jun 2, 2007 | 04:06 PM
jagsta's Avatar
Car: 1991 GTA
Engine: 305 (F)
Transmission: 5 m
Axle/Gears: 3.08
I found that in my 91 ta 5.0 5speed tpi Bosch +4 works the best it means it has 4 prongs on the end istead of just 1 like most spark plugs the are expensive but most likely you won't have to replace them again unless one fouls out..
Old Jun 2, 2007 | 04:16 PM
jonmark1985's Avatar
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
never use a bosch plus four, ive seen huge warranty claims when i was in the parts business, the plug burns uneven and chunks of porcleain fall off into the cylinder wall,
also the plus four is a gimmick, electricity takes the shortest route, it will only jump the shortest gap of the four terminals until the gap is opened larger then another gap, then it will jump another gap until its opened up
finally i don't care what you say, never put a bosch plug in anything
Old Jun 2, 2007 | 04:33 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
For a moment there I though Capt Picard was back around, but no, that was two years ago.
Old Jun 2, 2007 | 04:53 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
I don't know for sure but this guy is from "Turkey" and maybe he dosn't have a very good choice of other spark plug brands??
Auggie
Old Jun 2, 2007 | 09:15 PM
<<K-O>>'s Avatar
Car: 88 TransAM GTA
Engine: 305 LB9
Axle/Gears: Stock
Auggie
Yes, Bosch is the most eaisly obtainable plug for me. It's available everywhere here. Acdelco and other brands are very hard to find here they're sold for 3-4 times the price of bosch plugs.
Old Jun 3, 2007 | 12:23 AM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
2 years ago i put bosch in my formula and it ran find for about 3,000 miles. after that it had performace problems. it ran like crap. I pulled the bosch out and put back good old AC delco and it ran like a champ again. I WILL NEVER USE BOSCH IN A THIRDGEN EVER..
Old Jun 3, 2007 | 01:23 AM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
bosch plugs suck... delco all the way.
in my experience small block chevys dont like anything other that regular delco resistors. even delco plantinums seem to screw them up. at least the older ones like mine
Old Jun 3, 2007 | 11:20 AM
Auggie's Avatar
Well, that could be true but my NO2 fed (150 shot) 355 has NGK UR-5's that I installed in 1995 with a set of Accel 300+ wires. Hasn't missed a beat and the UR-5's are the short plugs that work great with headers.
Auggie
Old Jun 3, 2007 | 01:13 PM
F-Body Demon's Avatar
+1 I am in the parts buisness as well and all I have to say is Bosch is CRAP. Period. End of story. Go with AC Delco Rapidfires , my new favorite.
Old Jun 11, 2007 | 08:14 PM
I'm around here somewhere!!! Escaped the Borg and now back at the helm..
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
Gunsbee
Sep 7, 2015 07:10 PM
Jlanz55
Sep 6, 2015 03:05 PM
