What HEI ignitoin should i get?
Subscribe
Jun 12, 2004 | 01:54 PM
i want to get a HEI ignition to replace my old one (hey if u gotta do routine mantinace might as well throw in a few performance parts while at it )
i want accel or MSD but idk which one will fit.
and one that would fit a 350 and my lo3 305 at the same time would be great (future project).
Reply 0
Jun 12, 2004 | 02:05 PM
Distributors "fit" the same whether the engine is 305 or 350 (or 262 or 265 or 283 or 307 or 327 or 400 or 396 or 426 or 454 - I probably missed a few in there).
What you need to know is whether you are going with a computer controlled system (like the TBI that came from the factory), or non-computer controlled such as would be used with a non-concomputer controlled carb.
Or, were you talking about an aftermarket box to improve spark? (Same answer, though.)
Reply 0
Jun 12, 2004 | 06:21 PM
What he said. You know your car has an HEI unit in it already right? Are you looking for an MSD billet crank or spark box? We need to know exactly what it is you are trying to figure out.
Reply 0
Jun 13, 2004 | 12:33 AM
my car already has a HEI distirbutor?
im looking for a distributor, and which would be the best.
Reply 0
Jun 13, 2004 | 12:48 AM
What's wrong with what you've got?
Are you talking about a stock computer controlled type, or something without computer controls?
Reply 0
Jun 13, 2004 | 12:52 AM
Whats wrong with using a GM unit? If its working properly and set up right, there in really no HP to be gained by spending 10x the money on aftermarket stuff.
Just get the right springs (leave the weights alone) and maybe a coil with a little more kick, and its gonna make just as much power as any $1000000 aftermarket HEI will.
(I assumed you wanted a non-CC distributor here)
Reply 0
Jun 13, 2004 | 01:06 AM
well my car has 131xxx miles on it and im assuming its the stock one, so i think it should be replaced soon, along with plugs and wires.
and u guys keep talkin about computers and **** and i kno nothing about car computers.
Reply 0
Jun 13, 2004 | 01:16 AM
You can't just replace the distributor to a non-computer controlled distributor. If your not going to get rid of the computer and all the computer controlled stuff, you can't get a different distributor. There is nothing wrong with the on in the car now is there? Probably not! All you need is a new distributor cap and rotor, some wire and some spark plugs to tune up the ignition system.
Reply 0
Jun 13, 2004 | 08:38 AM
Borsty, yes the distributor you have is already an HEI. You can rebuild it if you need to, I'm pretty sure that has been covered before. If you are looking for an aftermarket unit for some reason, most aftermarket distributors sell them.
Reply 0
Jun 14, 2004 | 05:47 PM
Quote:
Not completely true.
http://store.summitracing.com/partde...art=MSD%2D8366
But then, the question "What's wrong with yours?" still needs to be answered to justify that expense.
It doesn't include the coil, which is a weak point of the stock ignition.
Reply 0
Jun 14, 2004 | 07:25 PM
Cool, i learn something everyday. I was wrong again.
Reply 0
Jun 15, 2004 | 06:41 PM
If I were you I'd Just replace the Cap, Rotor, Coil and wires with MSD components. Cant go wrong there.
Reply 0
Jun 15, 2004 | 11:54 PM
what the heck is a cap and rotor?? sorry if its a dumb question but i've looked on the msd site for a cap and rotor but i can't find anything there....and i have absolutely 0 clue what the heck it is
Reply 0
Jun 15, 2004 | 11:59 PM
a cap is the plastic part with the 8 things pointing out of it with caps on the end of the dist. and the rotor is the part on the inside which spins and gives spark to a different wire at a different time.
hope that made sense.
Reply 0
Jun 16, 2004 | 12:00 AM
OOHHHHHHH alright, i gotcha now, thanks for the help
Reply 0
Subscribe
