SES light but no codes???
Car: 87 iroc
Engine: L98 350
My car runs for 1-2 seconds and shuts off... I get the service engine soon light so I checked the codes, all I get is the code 12 over and over again. Nothing else. Any thoughts???
Car: 1989 Iroc-Z
Engine: 5.7L TPI
After the car shuts off the Service Engine Soon will come on because there is power going to the circuit with the key turned. It is just like when you first turn the key to the "ON" position the light will come on as part of a bulb test. There was no code thrown. Have you checked the fuel pressure?
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Originally posted by WishIHadAZ
Red devil, what are you basing that on? Or is it just a precaution thing? The relays were both replaced fairly recently actually...
My car runs for 1-2 seconds and shuts off... ...all I get is the code 12 ... Any thoughts???
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
hi guys this is (gen3z)i have to use a different screenname at work for some reason,now to the answer to your question if your car is not running long enough for the ecm to store a code it will do this it has to run for at least 30 seconds to do its code storage so make it run for at least that long to try to repair your car...
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
First thing i would do is buy a noid light, make sure all your injectors are firing. Noid lights are only about $6.00 at the auto zone.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Disconnect all the injectors and test each one by plugging the noid light into the connector and having someone crank the engine and observe the light. If the light pulses or flashs, then you have a good circuit to that connector. If you get one, make sure it is the one for GM TPI systems as there are several different models of the noid light on the store shelfs these days.
eightsixseven
Dec 16, 2024 01:50 PM
