Fuel pressure help needed.
Old Jun 16, 2004 | 12:59 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I am running a intank TBI fuel pump right now. It is about 2.5 years old. I swapped to carb about 1.5 years ago. I am running a 3 port return style mallory fuel pressure regulator. I recently got around to installing a real fuel pressure gauge...not a cheap POS from autozone.
I was running way to much so I turned it down to 5psi. Next day I go out to check and its at 2psi. Turn it up...it will be at 10psi the next day. This keeps happening.
Is it possible the TBI pump is finally dieing? I have a holley blue fuel pump I am about ready to install. Think this will help anything?
Old Jun 16, 2004 | 05:30 AM
ede's Avatar
ede
sounds more like a regulator problem
Old Jun 16, 2004 | 10:59 PM
Transmission: 4l60e
I also have a holley regulator that came with my holley blue pump. I had planned on using that for my nitrous soleniod but I may not be able to.
For a 100 shot of nitrous do you think I could just use the holley reg...run the fuel line in and run one line to the carb and one line to the fuel soleniod? Its a holley blue so it should be able to supply enough fuel that way.
Old Jun 17, 2004 | 12:19 AM
Transmission: 4l60e
Ok I got a few pictures...I do not see how the regulator could be messed up. It is too simple.
I had my fuel return line on the bottom port and the inlet/outlet on 2 of the other ports around the top.
Now that I look at it it appears that the fuel should be coming in the bottom...I don't see how it regulates if its connected to the side ports.....
Old Jun 17, 2004 | 12:21 AM
Transmission: 4l60e
Here is the inside piece....
Shouldn't the fuel pressure be coming in from the bottom and forcing the cone upward? Which would create tension on the sprigs....so screw the reg down should inturn cut fuel off correct....
Old Jun 17, 2004 | 10:17 AM
Damon's Avatar
No, fuel supply should defintiely be coming in the side and the line to the carb should also be coming out the side as well. Bypass goes on the bottom.
The bypass opens by the pressure inside the main body of the unit pushing up on the diaphragm and lifting the needle valve off it's seat to bypass excess pressure back to the tank.
There's another post similar to this in the Carb section you may want to check out.
Old Jun 17, 2004 | 10:25 AM
PhilM's Avatar
Car: Accepting applications...
Damon is exactly right, you might have had it backwards on the hookup.
I have fluctuations in pressure with my setup (which is exactly the same as yours), but not more than .5 PSI.
Old Jun 17, 2004 | 12:40 PM
Transmission: 4l60e
I had it hooked up right. Return line was on the bottom and the inlet/outlet were on the sides.
I still think my fuel pump could be going bad. I am getting ready to go buy some fuel line so I can hook the holley reg up and see what happens.
Old Jun 17, 2004 | 08:27 PM
krly79's Avatar
Car: '93 S10 Short bed standard cab
Engine: 383 Stroker
Transmission: 92' stage 2 700r4 w/3600 stall
if you are running a TBI pump that pushes alot more psi than what your carb needs and you are using a pressure regulator on it to keep the psi's down, then your pump could be burning up. I've heard of that before once or twice.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
