Do I stand a chance against this Trans Am????
Old Apr 5, 2001 | 04:05 PM
CamaroX84's Avatar
This guy at school has a 95 Trans Am (No ram air) with the following:
LT1 engine, 6-speed manual trans, K&N Air Filter, New Injectors (High Performance, not sure what kind or flow rate), Throttle Body Air Foil, High Performance suspension springs, Borla Cat-Back Exhaust, 4.10 Posi rear
I will have the following on my 84 Camaro in a month or so:
355 MAF TPI motor, forged aluminum pistons, adjustible fuel pressure regulator, Crane Compucam Camshaft (214/220 duration @.050" 2000-5500 RPM range), Custom "Ram Air" with K&N's, Hooker Headers, 3" High Flow Cat, 3" Hooker Cat Back, 700R4 trans with a high performance torque converter (not sure stall speed yet), 3.23 Posi rear
I know I have a ton more done to my car, but he's got an LT1 with a 6-speed. Keep in mind that he is 16 years old, so I don't know how good his shifting is, but he could be real good. Any help is much appreciated. Thanks.
Old Apr 5, 2001 | 04:07 PM
Bort62's Avatar
Stock Heads ?
I think it will be Close, and Depend Alot on how well you Tune your setup, and On his Skill.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Apr 5, 2001 | 04:18 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I think you will get drilled if he can drive; I'd guess his car is a good .3 and 5 mph faster than yours, maybe more.
But don't let it bother you. Have fun, do the best you can, race fairly, be safe, win or lose graciously. Every race has both a winner and a loser, and there's no shame in getting beaten in a well-run race. Work on your driving technique so that you force his car to beat your car, rather than it being a case of him beating you, or worse yet, you beating yourself.
But don't worry about what people on this board say, go race him and tell us what happened. And remember: it's supposed to be fun!!
ICON Motorsports
Old Apr 5, 2001 | 05:51 PM
CamaroX84's Avatar
We both have stock heads, except mine have matching springs/retainers for the new cam. I also have had a radius valve job done to mine. Thanks.
Old Apr 5, 2001 | 05:59 PM
84FTA's Avatar
<font face="Verdana, Arial" size="2">Originally posted by CamaroX84:
</font>
From his set-up my guess is he is dipping into the mid to low 13's. Do you know he has this for sure or is he talking crap?
</font>
Will there be a shift kit on your tranny? IMHO I don't think he will annihilate you or anything, just because he has 4.10 gears doesn't automatically make him faster, it's not always that straight foward (I commend the gears article for mentioning this fact).
It sounds more like a toss-up and a bit in your direction being the kid is 16, and probably can not drive. If only you had aftermarket heads it'd be so much easier....
1984 WS6 Hardtop Trans Am
Former L69 Car under restoration
1984 T-top Trans Am
4-bolt main 350, performer intake, headers, Holley 650, T-5, hayes clutch, dual elec. fans and 3.23's.
Daily driver and restoration
13.98 @ 101
Old Apr 5, 2001 | 07:33 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
he probably cant break into the 13's and will most likely click off a 14.2-3 with his mod. Its essential that you get the jump, that will be where he will roast his tires.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, 3000 stallconverter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
Best time yet to come
12's?? :crossthumbs:
This is a Pic of my car in race trim www.tbns.net/billyjay/camero.jpg
Yes I know how to spell camaro- so dont ask. I didnt make the link
Old Apr 5, 2001 | 07:50 PM
84FTA's Avatar
With a shiftkit, TPI mods and his set-up he ought to break 13's atleast. Look at my car and I hit 13.98.
1984 T-top Trans Am
13.98 @ 101
Old Apr 5, 2001 | 08:02 PM
ede's Avatar
ede
go race and find out, anything can heppen for real and bench racing proves nothing
ICON Motorsports
1st & 3rd
MM Black Diamond Lodge 538 F&AM
Old Apr 5, 2001 | 08:13 PM
CamaroX84's Avatar
But really, if you look at it, he doesn't really have much engine work done. A K&N and an airfoil won't provide that much power. And with the new injectors he has, they wouldn't do much for him, because he doesn't really have the engine to harness the ability of those injectors. Am I right? Or am I ust talking out of my a$$? What do you think my car would do in the 1/4 just out of curiousity? Thanks again guys.
Old Apr 5, 2001 | 08:29 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Go race.
Your car should be in the 14.7 range; his car should be 14.3 or so. You're down about 25-30 HP to him.
You will win if he lights up his tires at the start. Practice your starting line technique: that's where the race will be won or lost. The way to start the best, is to hold your left foot on the brake as hard as you can so the car doesn't move; with teh car in gear, rev the engine up to the converter stall speed, or just below (you can figure this out with a little practice); at the start, release the brake suddenly, and ease into the gas as fast as you can without breaking the tires loose. If he spins and you hook, he'll be seeing nothing but your tail lights for a long way down the track.
This is going to be at the track I hope?
ICON Motorsports
midge54
Sep 2, 2020 07:13 PM
anesthes
Mar 10, 2016 10:35 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
anesthes
Aug 26, 2015 01:37 PM
L98GTA87
Aug 25, 2015 02:23 PM
