stock lifters ok on a rebuild?
Old Jun 18, 2004 | 01:24 AM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
is it ok to reuse the stock hydraulic roller lifters from a 350 on a peformance 383 rebuild? please don't just say no unless you've personally had a bad experience doing so or if you know someone who did. also, id like to hear if anyone has done this with success.
Old Jun 18, 2004 | 01:30 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What lobe lift are you thinking about using?
Old Jun 18, 2004 | 01:32 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Yes it is possible to reuse the lifters, if they are in good shape and the cam is not too radical.
Old Jun 18, 2004 | 02:16 AM
cormyr's Avatar
Engine: 383 miniram
cam is a zz-409 w/ 1.6 rr, .560/.560 lift, 226/226@.050, 112 lsa
Old Jun 18, 2004 | 05:41 AM
ede's Avatar
ede
what are you asking, if it's ok to reuse lifters, or if stock lifters are ok for a preformance application? either way i don't have any personal experience doing it nor do i know anyone that has so i can't answer.
Old Jun 18, 2004 | 09:28 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I did a rebuild on my L98 350 then put in the HOT cam with my old rollers. I just had the shop vat clean them and I took each one apart and cleaned all the little parts inside, reassembled and they have been great. Just make sure the rollers are fine, ya know, common sense stuff like that.
Old Jun 19, 2004 | 12:24 AM
cormyr's Avatar
Engine: 383 miniram
machine shop tried to tell me id break my lifters with this cam and upgraded valve springs. i think he was just trying to get me to spend money. anybody out there ever break their lifters?
Old Jun 19, 2004 | 01:00 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Break 'em? Yep. Lots. Gixx: https://www.thirdgen.org/techbb2/sho...box+AND+lifter
Then ther was one where someone had a nitrous sneeze and screwed up a ton... you should narrow that question a bit.
Old Jun 20, 2004 | 12:37 AM
cormyr's Avatar
Engine: 383 miniram
reddevil it appears that lifter broke because of valve float. he was running a miniram and shifting at 7k. my setup is with a superram and will only be revving to about 6200 max. also have stiff valve springs to combat float. im thinking with this setup it should be ok.
Old Jun 20, 2004 | 08:02 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Yep and it was to illistrate how others had broken theirs, i.e. don't listen to the guy at the machine shop.
sweet_87_iroc
Sep 25, 2015 10:01 PM
Cameeeero
Aug 20, 2015 03:06 AM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
