answer this one smarties!!!
Old Apr 5, 2001 | 11:43 PM
burnoutrpm's Avatar
my car with the engine listed in my sig keeps losing oil pressure day by day!! it now running 25 psi on the highway!! this really sucks..... about 5- or 6 at a stop light!! ive heard it could be the restrictor plug under the rear main cap isnt there??(the one in the block that makes the oil go through the filter!!) i think there isnt anyway that its a main or rod bareing i hammer the car wayyyyy too much and it doesnt knock or start hard or anything??!! so i dont think that the mains or rods could be the problem!!maybe the cam bearings?? possible?? the oil pump is part number#m55hv
help this is a new engine and i dont want it to freeze up!!
89 firebird formula
356 10.5:1compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
Old Apr 6, 2001 | 12:00 AM
SUPER-SPORT-CHEVY's Avatar
Could be the oil pump is a pos! Just cause its new and a high volume dosent mean that melling couldent have screwed up. Ive never had a problem with a melling oil pump but that dosent mean that some one else wont have a problem. How old is the pump? If its less than a year it should be under warrenty just take it back and get another. While you have the pan off pull "one" of the rod or main bearings to see if its shot, that should give an indcation to the conditon of the rest of the bearings if their all the same age. looks like you have to pull the pan reguardless.GL
Old Apr 6, 2001 | 12:20 AM
burnoutrpm's Avatar
<font face="Verdana, Arial" size="2">Originally posted by SUPER-SPORT-CHEVY:
</font>
thanks for the response!! i figured the pan would need to come off ....that sucks!! that thing is a complete bitch to get out of the car!!the pump is brand new... not even 2,000 miles on it!! it spun ok by hand before i installed it!?? anymore help?
89 firebird formula
comp cams xe262 cam
#1405 edlebrock 600
msd 6al
Old Apr 6, 2001 | 12:24 AM
burnoutrpm's Avatar
<font face="Verdana, Arial" size="2">Originally posted by burnoutrpm:
</font>
thanks for the response!! i figured the pan would need to come off ....that sucks!! that thing is a complete bitch to get out of the car!!the pump is brand new... not even 2,000 miles on it!! it spun ok by hand before i installed it!?? anymore help? sorry forgot the engine has ALWAYS had this problem!! even with m55 normal pump!! the clearances were .0002 on the rods and mains! it was a very tight engine and should hold better pressure!?? and the rods side to side clearance was fine crank was miked and so was the bearings and the rods have been miked and they were brand new!!the oil holes on the block were clean as were the cranks holes!
89 firebird formula
comp cams xe262 cam
#1405 edlebrock 600
msd 6al
Old Apr 6, 2001 | 02:03 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Is your oil pressure sender/ gage reading correct? Verify this with a mechanical oil pressure gage tapped off the oil plug by your distributor. I'd check that first before you rip out the oil pan.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
Old Apr 6, 2001 | 02:24 AM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
<font face="Verdana, Arial" size="2">Originally posted by IROCZZ3:
</font>
It has a mechanical oil pressure gauge in it already!! I keep tellin' him though that the gauge could be shot....but he doesn't think so!! I've seen what it does and it just doesn't make sense to me!!
Old Apr 6, 2001 | 07:47 AM
ede's Avatar
ede
first thing i'd do is screw a mechanical gauge in the block and see waht it says, and not the same gauge as is in the car now.
ICON Motorsports
1st & 3rd
MM Black Diamond Lodge 538 F&AM
Old Apr 6, 2001 | 10:06 AM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
I had 0 psi at idle and 8 on the highway.
No noise no thing.
First thing was first. I took of the oil pressure sending unit and found it was clogged with a bunch of crap.
Oil pressure was great after that.
Make sure you chekc the easy stuff before you go ripping the pan off......
Might save you quite a bit of headaches down the road.
Sportsman II 72 CC heads, Pete Jackson gear drive, Performance Resources chip, Edelbrock 1 5/8" headers and Edelbrock cat back exhaust, hi-flow cats, Trans-go stage 3 shift kit, Vigilante 9.5" 2800 stall convertor, SLP cold air induction, SLP roller camshaft, 24lb ADS injectors, AFPR, 3.45 rear end gears, and other goodies...
raven
grngryoutmyway
Oct 18, 2016 05:48 PM
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
