throttle sticking?
Old Jun 20, 2004 | 04:30 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
throttle sticking?
my throttle likes to stick at about 2000 rpms but only when the car is running. it moves freely when the car is off, but when car is running it will get stuck. Any ideas?
Old Jun 20, 2004 | 05:27 PM
Vader's Avatar
Possibly the throttle shaft is worn, and the vacuum from the running engine is binding the plates against the bores. Happens sometines.
Old Jun 21, 2004 | 05:10 AM
treeohfive's Avatar
does this happen when you hold the car qat a steady cruise at 2000 rpm? it could easily not stick when you are sitting there not running and just pressing the pedal down...then when its held at a stead position ...it sticks.
carb cleaner...clean the hell ouf of it....make sure none of the throttle cable lines are worn or crimping anywhere...also...does the car have cruise control by any chance?
Old Jun 21, 2004 | 07:28 PM
trueburton's Avatar
no lines are crimped and i just cleaned it and lubed it. That seemed to help out but it still stuck a little. I put and second throttle return spring on it and now it runs fine. Except i still have a vaccum leak somewhere.
Old Nov 23, 2008 | 07:31 PM
haygod's Avatar
Car: 1989 IROC
Re: throttle sticking?
I have the same problem and it does seem to be related to my cruise control.
Know something about this? Looks like I could adjust the cable at the cruise control diaphram but I'll wait to hear from you first. Thanks.
Old Nov 23, 2008 | 07:39 PM
Stephen's Avatar
Car: 87 GTA
I had a sticky throttle a few months ago, after I had my sloppy steering column worked on.
I was convinced they did something wrong. In away, they did.
The lower plastic panel under the dash...It wasn't up in place like it should have been, so it was rubbing on the throttle pedal shaft. "Wedging" it into staying open, after my foot came off the gas.
I started wondering about the floor mat, but that wasn't it. I looked under the hood...Nothing to make the throttle stick. I found the loose lower panel while crawling under the dash.
Your symptoms sound real familiar. Wouldn't hurt to check, to see if the lower panel fell down a bit.
Old Nov 23, 2008 | 09:05 PM
TylerP's Avatar
Car: 89 T/A and 97 Formula (sunny days)
Engine: 305 TBI / LT1
Transmission: 700R4 / 6M
Axle/Gears: 89 IDK / 97 3.73
Your car is a TPI? Sounds like an IAC valve going bad to me.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
DiabloWS6
20
Dec 11, 2015 04:12 PM
Scorched1984
Sep 15, 2015 03:42 PM
banksGTA
Sep 13, 2015 11:56 AM
Randomtask2
Sep 7, 2015 05:06 PM
