Can't apply torque to crank pulley bolts!!!!
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
On my '89 IROC with an auto tranny I am trying to torque down the bolts on my new underdrive crank pulley. With the car in park and e-brake on it simply turns as I apply torque to the crank pulley bolts. Any ideas on how I can tighten these bolts to their respective torque values??
It was very easy to do this mod on my '87 T-5 car!!
Thanks!
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, ZZ-9 cam, Edelbrock RPM intake, Hooker SC/LT headers, Edelbrock 750 cfm Carb (#1411), stock T-5, GM 3.42 rear w/Auburn posi.
Ohio Valley Dragstrip Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hyper Chip, gutted MAF, 53kv coil, MSD wires.
Thanks!
Phil87IROC
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Pull off the access cover for the torque converter and jam a screwdriver into the ring gear teeth. It helps to have someone helping you.
Guest
Posts: n/a
Impact wrench, get a TDC finder that threads into the spark plug hole and put it in. Get a cylinder with the piston down and pull the plug, push some rope down into the cylinder. When the piston comes up it the rope will compress and then stop the piston and allow you to torque the bolts. Then spin the motor the other way to allow yourself to pull the rope back out.
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
No theres an easier way - pull the e-brake and put the car in drive. When you put the car in park, the drivetrain locks, but the engine can turn freely. When in drive, the engine and drivetrain are connected, but since the e-brake is on, the drivetrain can't move, so neither can the engine.
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
1983 Firebird
TH700R4 Auto
Small Block 400
Car: 1986 Firebird
Engine: 2.8 V6
I thought the torque convertor needs to spin fast enough to get fluid transfer going though. I'd imagine the crank pulley would still spin, even though the car's off and in drive.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
CAREFULLY take a large pair of pliers and put a rag in the jaws. You can then gently grab the bottom pulley and prevent it from turning.
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
I watched the 3rd ring gear get put into my Rear end, they guy torqued it down using his hands an an impact wrench. If you don't have one, the air compressor will cost about $120-$130, and the impact wrench will cost ~$30-$40. I have seen some electric impact wrenches, but my dad didn't have much luck w/ them
Corry Lazarowitz
clazarow@voicenet.com
clazarowitz@hotmail.com
SLP 1 3/4" headers, 3" cat back (stock cat
)MSD ignition. MSD Blaster SS coil. More soon when funds are avail...
Corry Lazarowitz
)MSD ignition. MSD Blaster SS coil. More soon when funds are avail... Supreme Member
Car: Take
Engine: Your
Transmission: Pick
<font face="Verdana, Arial" size="2">Originally posted by Ward:
</font>
</font>
Apparently you forgot the function of the Torque Converter. You also have not tried this, or you would have realized it does not work.
[QOUTE]Originally posted by Corry:
I watched the 3rd ring gear get put into my Rear end, they guy torqued it down using his hands an an impact wrench. [/QOUTE]
Put together w/ an impact wrench!?!?!? Did you ever stop and think maybe that is why its the THIRD RING GEAR?
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
[This message has been edited by GMTech (edited April 07, 2001).]
evilstuie
Jan 9, 2020 08:29 PM
ambainb
Apr 25, 2016 09:21 PM
Navy8125
Aug 22, 2015 07:13 PM
Street Lethal
Aug 12, 2015 11:33 AM
