Better gas mileage for L98
Old Jun 21, 2004 | 01:10 PM
C_A-Formula350's Avatar
Car: 1991 Formula 350
i was wondering how people who own 3rd gens are able to get 30mpg on the frwy. i have a 91 formula350 and it gets 10 in town 18 on the frwy if i am lucky. i have repaced the timing chain, water pump, knock sensor, spark timimng module, egr valve, egr solenoid, cap, rotor, plugs, wires, and i think a few other sensors. it is frustating to get poor gas mileage and i know it never had great gas mileage but when i see somone with basically the same set up as me and getting that kind of gas mileage i am jealous.
thanks
Old Jun 21, 2004 | 01:50 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
What gears do you have? A lot of it has to do with the way you drive. Start off slow never going past 1/4 throttle and let off the gas when coming to a stop more then 100 yards away.
Old Jun 21, 2004 | 03:01 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Re: Better gas mileage for L98
thanks
Something is definitely wrong there!
You should get at least 15 or 16 mpg around town and 25 or so on the highway. Must be a sensor that is giving bad info.
Old Jun 21, 2004 | 03:18 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
Kind of a Duh...but have you changed the O2 sensor? How's the trans?? If its slipping I'd imagine that could hurt you too. TQ Converter locking up, I think that improves mileage?
Old Jun 21, 2004 | 06:48 PM
yeah new O2 sensor as well, i dont drive it hard only when i am entering the freeway. it has been runing kind of wierd lately. My car for some reason threw a code 46 yesturday and for some reason after changing the egr valve and egr solenoid i am still getting a code 32, i cleared the codes after i replaced the solenoid and valve. anything/ideas would be great. i would just like a bit more mpg.
thanks
Old Jun 21, 2004 | 06:49 PM
oh trans was rebuilt less than 2 years ago too and i believe i am running 343 or 373 gears.
Old Jun 21, 2004 | 07:57 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
sounds like the gears could be the problem,, what are your rpm's on the highway, at say,, 65? Mine with the pos 2.77 is like 1600 or so,, and I was getting 26, 23 with the supercharger on.
Old Jun 21, 2004 | 10:51 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
check your:
o2
timing
vaccume readings for vac leaks
compression check to check for worn cyl/rings
also could be worn/clogged injectors that are leaking fuel
Old Jun 21, 2004 | 11:01 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
keep in mind, fuel economy is not only determined by the engine and its peripherals, but the tires and setup as well. You need to have proper alignment and tire PSI as well.
Old Jun 22, 2004 | 02:37 PM
well my rpms at 70mph is 2100 so it isnt to high i think, i wish i had a 6 speed but the 700r is good i guess for now
Old Jun 22, 2004 | 04:34 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Thats not that bad, at 70mph i'm turning 3500rpm. I still manage to get 20mpg on the highway though.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
