Car Broke Down Half Way To The Track
Old Jun 24, 2004 | 03:38 AM
JesasaurusRex's Avatar
Well the title pretty much explains it. Ive been having this problem before. After the car warms up it wants to die out and well it will. Couldnt tell you if the cars over heating or not cuz I kinda messed up my temperature guage. But I just bought a brand new Modine Aluminum radiator, new thermostat and the water pump is fairly new, fan still runs so ya. If I let the car sit for a while (cool off) and start it again itll run until it wants to die again. How long inbetween depends on how hot I guess it is. No intake leaks I even took the manifold off and resealed the whole thing. Only thing that It could be is the water pump that im guessing even tho its fairly new. Its not seaping out the wheep hole but does it have to if the water pumps bad? All the information I can really give you. Plus my car leaks a lot of oil
Old Jun 24, 2004 | 05:26 AM
ede's Avatar
ede
think i'd get the temp gauge working so i knew what was going on with the engine and go from there.
Old Jun 24, 2004 | 12:07 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
starter solenoid getting too hot?
Old Jun 24, 2004 | 12:09 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Ummm, the starter solenoid has nothing to do with the engine once its started...
Old Jun 24, 2004 | 12:37 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
could be the ignition control module. They will fail when they get hot. But I agree with ede on getting the gauge fixed first.
Old Jun 24, 2004 | 01:48 PM
EYEROCK89's Avatar
Car: 1989 IROC
Engine: 5.7 / 350 cuid
Are you getting any trouble codes?
The first time my car did this, it was the ignition module and connections. The second time, it was the EGR system. The third time, it was well...I don;t know, I haven;t been able to find the problem this time. I guess it;s like they say, third times the charm.
Old Jun 24, 2004 | 03:36 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
i guess that most of these people didn't notice that you were running a carb conversion setup. Codes, HA! Anyway, what is your timing at, it maybe retarded a lot, OR your Edelborck carb maybe getting hot from sitting on the manifold and boiling out all the gas before it goes into the engine, I think it is called vapor lock. Just plain getting hot shouldn't kill the engine. The motor should run until it seizes if you let it.
Old Jun 24, 2004 | 03:57 PM
Timeing isnt too retarded cuz I had it way advanced and retarded it a lil just cuz I thought I might have had it too advanced. WTF is the ignition module lol.
Old Jun 24, 2004 | 06:26 PM
K guys I put my lil temp guage thing back into the block and when I unscrewed the old plug almost no coolant dripped out so im pretty sure its just over heating. Id have run it just to check but I just broke the 4th starter this week which I still donno y thats been happening. Oh wellz ill keep yawll posted thx guys, might just push start it to see if its the temp or not.
Old Jun 30, 2004 | 01:28 PM
K not overheating still same **** going on DAMN IT. Vapor lock is what im leaning twoards now. What does everybody else think?
Old Jun 30, 2004 | 04:52 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
Where is your temp, now that you put in a gauge, when the car dies?
Old Jun 30, 2004 | 05:01 PM
Keith_Indy's Avatar
Car: 87 Firebird Formula
Engine: 305 LG4
Vapor lock sounds like a good suspect.
The old way of solving it would be to throw a couple of close-pins on the fuel line. Should act as a heat sink, and you might be able to diagnose the problem that way.
Didn't see what fuel pump you're running...
Old Jun 30, 2004 | 05:05 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
Cloths pins on the fuel line won't do crap as a heat sink. ANy clothes pin you find today will be either wood or plastic and neither is a good source of heat transfer.
Old Jun 30, 2004 | 05:11 PM
ruiterman's Avatar
Car: 91 Z28, 89 Formula, 85 IROC Z28
Engine: 305 TPI, 305 TBI, 305 TPI
Transmission: 5 Speed, 5 Speed, 700R4
Did you check the spark?
I hear a lot of talk about vapor lock. Did you check your spark after it dies and won't start?
It is either fuel or spark. Hard to figure out what the problem is if you don't know which of these to focus on.
I had an 88 Pontiac 6000 that would die after 15 or 20 minutes. I pulled a spark plug to check spark. Nothing. Let it cool for awhile, spark came back.
Once you know fuel or spark, then you can focus on the vapor lock or ignition.
Old Jun 30, 2004 | 05:28 PM
...Spark Plugs have sat 4 a while. Ill get some new ones, I also got some braided fuel line so that should help with the vapor problem if that infact is the problem. Fuel Pump is stock TBI pump, using a FP regulator with it. Ill keep yawll posted.
Old Jun 30, 2004 | 10:23 PM
K well got braided hose, spark plugs, still same ****. So after it did it, I yanked the main feed line again and turned the ignition on. Fuel came out 4 a second then it just stopped. So im 99 percent sure my fuel pumps going. I was just gonna get a Holley Blue and yank the in tank one out. My friend said it would be 2 much trouble and id be better off just getting a stock replacement and keep using my regulator. What do you guys think?
Old Jun 30, 2004 | 11:00 PM
My friend tells me id be better off just getting a stock type replacement and keep using my FP regulator. I was thinking about going with the holley blue/red and just ganking the FP regulator all together. However he tells me it would be a PITA to do and I should just get another intank one. Would like to hear from people who have done a holley blue/red conversion and also if it truely would be a lot easier to get another intank one who knows an aftermarket company that actually makes one for a TBI car that flows a few more GPH than stock? Thanks guys been lots of help :hail:
Old Jul 1, 2004 | 08:15 AM
Keith_Indy's Avatar
Engine: 305 LG4
Funny, that always worked on my fathers 68 Fury. You do want to use wood cloths pins if you try this.
Ghettobird52
Jul 5, 2024 11:18 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Brcharrelson
Aug 26, 2015 07:47 PM
kyleb24
Aug 15, 2015 08:24 AM
