Rocker Arm Clearance, Need Tall Valve Covers?
Old Jun 24, 2004 | 01:50 PM
onebadassbird's Avatar
Car: 91' Trans Am
Im in the midst of building an early 350 for my 91' TA. I am gonna be using 1.6 rocker arm and was wonder if I will need to use tall style valve covers. Im trying to stay away from them if possible to keep clearence issues with the EGR and Alt. to a minimun.
Are there any 1.6 rockers arms that will fit under say, the edelbrock elite low profile valve covers. I searched around and saw that maby the comp cams magnum roller rocker might fit under stock height...
Old Jun 24, 2004 | 02:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The Magnum roller-tip rockers will fit under any stock-height valve covers. They are not roller rockers.
The ratio does not matter.
Any rockers that use PolyLocks, including roller ones, will not fit. The PolyLocks are too tall. Again, ratio does not matter.
Old Jun 24, 2004 | 02:29 PM
Car: 91' Trans Am
Ok I got it now, thanks for the info.
Old Jun 24, 2004 | 04:27 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, I think there two lengths of PolyLocks. Long & short.
Auggie
Old Jun 24, 2004 | 04:39 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup.... the long ones are for stud girdles.
Neither one fits well under most stock-height valve covers.
Old Jun 24, 2004 | 07:17 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
So, is there a taller centerbolt valve cover available with all the factory holes for PCV, oil fill, etc ?
Old Jun 27, 2004 | 06:57 PM
rangelec's Avatar
I am running 1.6 crane roller rockers with vortec heads and a HOT cam-all under stock valve covers without any clearance issues. I used clay on top of the rocker during assembly to verify and there was more than .125" clearance. If you try it check clearances before you run it. I have about 10,000 miles on this combo w/o problem. And it looks SO stock. They do make tall centerbolt covers-check ebay.
db057
Sep 4, 2015 07:57 AM
Thaney9
Aug 29, 2015 03:16 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Cameeeero
Aug 20, 2015 03:06 AM
