GM '96-'97 L31 Vortech heads on 86 LG4
Old Apr 7, 2001 | 12:43 AM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
Has anyone tried the swap of GM '96-'97 L31 Vortech heads on their 305. Any problems with the swap. How about timing, will my engine need less advance? Should I change my intake or can I use the stock one? Any other FI heads work?
1986 Camaro Z28
White w/ T-tops
Tinted Rear Window
ENGINE
305 H-code
Gasket-matched heads and intake, ported and polished
Comp Cams 224 @.050
.472 lift I/E
Dual Snorkel Air Cleaner w/ K&N filter
Accel 8.8mm wires
TRANNY
700-R4 w/custom built 3000 stall converter
tranny cooler
EXHAUST
Flowtech Headers
No cat
Dynomax muffler
STEREO
Alpine CDA-855
Kenwood 4X6's, 6X9's
MTX 4240 amp
2 Sony 12" X-Plod's
Alpine 8440 alarm
Uniden 6599 Radar Detector
Take 'er easy, and if
she's easy, take 'er twice!!!
Old Apr 7, 2001 | 03:17 PM
BrianF's Avatar
Well I am in the process of doing the swap I am having .020 milled off the heads, using flat top pistons. You will need to mill about .035 to .045 to get the compression up to a good point. Yes you will need a new intake and stock to hot timing is good.
Need any more let me know.
Brian Felts
Old Apr 7, 2001 | 05:06 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Here's a 305 buildup article where they end up w/ Vortec head on their LG4. It may answer some of the questions you may have. They made some pretty good power w/ nothing radical in the engine at all...
Go to this link for the first page, then manually change the page1.jpg in your browser to page2.jpg etc to view the other pages... 5 or 6 pages total I believe. <a href="http://www.inter-scape.com/ray/305buildup/page1.jpg">LINK HERE</a>
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
[This message has been edited by Ray87Z (edited April 07, 2001).]
Old Apr 7, 2001 | 09:38 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
I put a set of vortecs on my LG4 last summer, I left the heads the way they were and lost a lot of compression, but it was a huge improvement over the stock heads nonetheless.
I left them because I had plans for a 350 swap anyway.
the gap for vortec heads are .065, which is a huge gap, i gaped my plugs to that and found myself needing a whole lot of timing advance and a very rich carb setting. gap your plugs to your normal .035 since the ignition on your car is not the same as the trucks which the heads come off of. your timing and carb shouldn't need too much adjusting that way.
and you will need a vortec specific intake cause of its crazy bolt pattern.
Old Apr 8, 2001 | 02:22 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
been done many times even in magazines and they aren't vortech, they are vortec. the years are from 96 and up. still being made for the L31 now.
Old Apr 8, 2001 | 05:31 PM
Hummer's Avatar
Car: 1986 Z28
Who`s intake manifold did you use? part #? Like it?
Old Apr 8, 2001 | 10:48 PM
Hummer's Avatar
Car: 1986 Z28
Old Apr 9, 2001 | 12:58 PM
Hummer's Avatar
Car: 1986 Z28
I'll try again...^^^
84z96L31vortec
Aug 20, 2017 12:16 AM
92projectcamaro
Jan 18, 2016 08:00 AM
z28guy134
Sep 1, 2015 11:50 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
