what do you guys run for engine oil?
Old Jun 26, 2004 | 07:20 PM
82crossfire's Avatar
Car: 1982 chevy camaro
Engine: 305cfi
what weight does everyone here run in there third gens.? i recently aquired mine and before i get it on the road one of the few things i want to do is change the oil. my Haynes manual says regular 30w. this seems real thick to me?
Old Jun 26, 2004 | 07:22 PM
VA1991Z28's Avatar
Car: 1991 Z28
Transmission: 5-spd
Mobil 1 10w30
Old Jun 26, 2004 | 08:09 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
5w30
Old Jun 26, 2004 | 08:43 PM
ede's Avatar
ede
my haynes manual list several oils depending on temp. i'd use 5w-30 or 10w-30
Old Jun 26, 2004 | 10:20 PM
Merlin's Avatar
Exxon/Mobil polyalphaolefin based 15W50 - summer driving only.
Old Jun 27, 2004 | 12:22 AM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
lol. i find this thread amusing. i think youll find a hundred different types of oil being used. i think whats more important is how often you change it.
Old Jun 27, 2004 | 12:27 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
No offense but...
Maybe something along the lines of 'Best Oil' or 'Oil preference' or some such. Should give you hours of reading.
Old Jun 27, 2004 | 12:32 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What Devil said. The search is your friend.
<A HREF="https://www.thirdgen.org/techbb2/search.php?s="> I like this oil</A>
Old Jun 27, 2004 | 01:01 AM
90_WS6_Formula's Avatar
Car: 91 Z28
Originally posted by VA1991Z28
Mobil 1 10w30
ditto!!!
Old Jun 27, 2004 | 05:31 AM
vampiroc's Avatar
Car: Z28
15W-50 in the summer and 5W-40 or 0W-40 in the winter, all Mobil 1
Old Jun 27, 2004 | 12:37 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
All our race motors get broke in using Valvoline straight 30W, first batch initial break in, 1 more fill up to help seat the rings, then switch over to Mobil 1 5W-30 full synthetic
Old Jun 28, 2004 | 09:07 PM
SinthetikIroc's Avatar
Car: Corvette
Engine: 5.7
0w40 cant be good for your motor
Old Jun 28, 2004 | 09:21 PM
Parrydise7's Avatar
I like synthetics and I've had good luck with them. Now, agreeing with the comment about the search feature, there are a lot of members (checks drawer for clean nomex underwear) that are running Wal-Mart brand synthetic (and filter, btw).
If what has been posted is correct, Wal-Mart brand synthetic is actually Valvoline. Wal-Mart brand oil filters, if the posters are correct, is made by Champion Labs, the same company that makes the Mobil 1 filter, although it is not the same construction as the Mobil 1 filter.
(Dusts off flame suit).
Old Jun 28, 2004 | 09:24 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Mobil 1.
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Mobil 1 15w 50
Old Jun 28, 2004 | 09:27 PM
Tremo's Avatar
Actually, the Wally's synthetic is made by Warren distributing. Who knows what they blend it with??
Plenty of info on the BITOG forum on this.
Old Jun 28, 2004 | 10:10 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
I've always run 20W-50 year 'round, and I've been using Valvoline MaxLife since it's come out. Depending on where you live, you might not want that weight, but I'd bet your 24 year old engine would appreciate MaxLife in either 10W-30 or 10W-40.
Old Jun 28, 2004 | 10:18 PM
Car: Corvette
Engine: 5.7
i run str8 30 always
Old Jun 28, 2004 | 10:59 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
mobil 1 10w-30
Old Jun 28, 2004 | 11:23 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
My brother works in the oil business, he talked to the guy at Mobil who invented Mobil 1. He recommends M1 15-50 for the summer and 0w-40 for the winter for a gen 1 iron SBC.
Old Jun 28, 2004 | 11:29 PM
MNformula350's Avatar
Mobil 1 15w50 with a AC Delco ultraguard gold filter (UPF25)
Old Jun 29, 2004 | 12:05 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Mobil Drive Clean 10W-30 with an AC-Delco PF454S filter. The best out there? No, not by a long shot I'm sure, but I was short on cash and needed cash to finish the rest of my tune-up as well, so its what I bought. Total cost of oil change? $10.44 and tax
Old Jun 29, 2004 | 01:46 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Always 20/50 for me...
Old Jun 29, 2004 | 02:01 AM
level's Avatar
Car: 1987 transam
Engine: 383 /w superram
Transmission: 700r4 /w 2800rpm stall
my engine isnt stock but i run 20w50 in my 383... this is with a high pressure/volume oil pump to move that sludge along
once its broken in tho i'm going with the heaviest synthetic
ow40 ... thats real thin i would never use that
Old Jun 29, 2004 | 02:49 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
It was interesting to hear what some of the NASCAR crew chiefs say about oil. I believe it was one of the Earnheart or Rousch crew who said they have tried all sorts of weights but finally settled on 0w30 synthetic. He said that every synthetic weight they tried came up with the same results--no discernable wear after a 500 mile race. Pretty conclusive in that regard.
But I agree that if you change your oil every 3000 miles it doesn't really matter what modern motor oil you use. It will be fine
Old Jun 29, 2004 | 07:57 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
L03 usually drinks havoline or whatever else is cheap... as thick as they sell it (it burns oil)
the 400 gets mobile 1 and the oil is changed once every 2 months (roughly 1500-2500miles)
theshackle
Mar 5, 2017 06:37 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
