snafu
Old Apr 1, 2001 | 05:15 PM
85F-body's Avatar
snafu
today my exhaust started making a wierd noise like it was a v-6 or something (i have a v8 85 camaro) and now my car does'nt accelerate as fast. i can't even peel out!!!! and the check engin light is'nt on or anything and i did change my air filters today i don't think that matters but i did
Old Apr 1, 2001 | 05:18 PM
ede's Avatar
ede
first thing i'd do is look and see if you messed something up when you changed the filter, knock something loose or unplug a hose
ICON Motorsports
1st & 3rd
Old Apr 1, 2001 | 05:45 PM
85F-body's Avatar
o ya and i have a borla muffler and 3 in. pipes
Old Apr 1, 2001 | 11:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds to me like one or more cylinders might not be firing.
Check for a plug wire knocked loose like ede suggested. If they're all on there where they belong, wait until the car is cold,; start it up and let it run for about 15 or 20 seconds; and take a detergent bottle or something and squirt a little water on each of the exhaust manifold or header tubes and see which one(s) fail to get hot, that's where the problem is.
ICON Motorsports
Old Apr 2, 2001 | 01:26 PM
86TransAmTPI's Avatar
I have to definately agree with RB83L69.That sounds exactly right on the money if you ask me,I know that when i had a couple lose plug wires that my car sounded like sh@t.And another time my friend who said he had the GM firing order rememberized,put my wires back on the distributor for me and he mixed up my firing order.Id check the firing order and make sure it right,make sure all your wires are on the cap and plugs snug,and also look into gettin a new cap,rotor and wire then if that dont cure it.Try pulling your plugs too and see if any looked fouled for any reason.Bye the way,what kind of wires and ciol you running?And do you have anything done to the car,performance wise?
Al in NJ
86 Trans Am 305 TPI,Bored 30 over,Blower Cam,Fordged Racing Pistons,High Volume Oil Pump,3" Flowmaster Exhaust,Hypetech Coil,Acell 300+ Race Wires,Bosch Platinum +4 Plugs.Best Et was 12.5 with a Paxton.
Old Apr 2, 2001 | 01:45 PM
Bort62's Avatar
hows that for "rememberized"
P)
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Apr 2, 2001 | 01:49 PM
91FireChicken's Avatar
Car: 91 Firebird
Transmission: A4
the firing order is stamped on the front of the engine. at least in mine it is.
Old Apr 2, 2001 | 07:44 PM
JPrevost's Avatar
Car: 91 Red Sled
Stand behind at idle and if your eyes water then fuel isn't being burned so you're not running on all cylinders. Check to see if all your wires are good. If you have bad arc then your car will run like crap and stall and will miss a lot. Another thing to check is the cat. It can cause lots of power loss and make your exhaust sound funny. Let us know what the problem is when you find out.
, Jon (350 TBI!)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)
  • Holley 670 TB unit w/ 1/2" spacer/adapter
  • Edelbrock RPM vortec intake
  • 350ho 330hp vortec crate motor
  • 8" harm. balancer
  • Stewart stage 2 water pump w/160 thermo
  • SLP tri-y headers to full 3"
  • Rebuilt trans w/ SLP shift kit
  • Centerline 16x8's all around
  • 36/24 mm sway bars
  • Full poly bushings, even motor mounts
  • SLP LCA and panhard
  • Alston SFCs
  • Edelbrock 3 point STB
  • Global west steering brace aka wonderbar
  • Eibach pro kit springs
  • Bilstien high perf. struts and shocks
  • All this and I still have AC
My websiteAny questions?
Old Apr 9, 2001 | 10:03 PM
85F-body's Avatar
what is bad arc???
Old Apr 9, 2001 | 10:06 PM
85F-body's Avatar
i changed the spark plugs today and made sure that the distributor wires were on there good and on the cap and everything is good but it still makes that noise at high rpm's and still has loss of power but it idles steady now too i don't know what the **** is the matter
Old Apr 9, 2001 | 10:12 PM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 85F-body:
what is bad arc???</font>
BAD ARC - n - t {slang) 1. a large boat that does not float; 2. any leaking vessel; 3. adj. - a basketball shot at too low an angle, with inadequate elevation.
...or in your case, weak spark.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 9, 2001 | 10:15 PM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Bort62:
18436572
P)
</font>
Bort,
LMFAO! You're one cold somma' bitch. (I'm gonna hafta rememberize that one for futural referralization...)
Later,
Vader
"What a Day..."
Old Apr 9, 2001 | 10:32 PM
Bort62's Avatar
haha Vader.
Incidentally, It is the Same number of Digits as an ICQ number, We should all send that guy a mssg, whoever he is
Old Apr 9, 2001 | 10:48 PM
85F-body's Avatar
well how would i fix the spark plug or the "bad arc"
Old Apr 10, 2001 | 03:55 PM
Master Of Puppets's Avatar
boom. rememberized. muahahaha.
88gta_hiflyer
Jan 22, 2010 07:40 AM
eldy
Jun 5, 2009 11:05 PM
Luther6704
Jun 22, 2006 04:16 PM
