Need help with correct starter motor
Old Jun 29, 2004 | 07:09 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I'm building a stroker motor using the block # 10105123.
My L98 stock starter does not fit. The bolt holes in the stroker block are diagonal, while the starter motor off of my old L98 are space straight across.
What starter motor can I buy from a Chevy dealership or Summit Racing which will fit the 123 block?
Old Jun 29, 2004 | 07:32 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You'll probably have to keep the L98 starter and just drill and tap a new hole in the block, like I did.
Old Jun 29, 2004 | 07:37 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Well, the engine is all built. I could not put the block into any kind of a mill or drill press. The extra hole has to be drilled very accurately. I'm not sure that would work out for me.
BTW: The flywheel has 153 teeth.
Old Jun 29, 2004 | 09:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It is not possible for a starter with the diagonal bolt pattern to fit a 153-tooth 12.8" flywheel. The inner bolt, the one closer to the crank, is correctly located for a 14" flywheel. But since the starter shaft for the smaller flywheel has to be about 5/8" closer to the crank, the inner bolt hole of the pattern for the larger starter would go RIGHT THROUGH THE MIDDLE of the starter drive.
Bottom line: the ONLY solution is to either drill the right hole, or change to a 14" flywheel / flex plate.
Old Jun 30, 2004 | 06:14 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
OK, lets say I attempt to drill and tap this hole.
The bolt is 3/8" NC16... I do have a tap & die set,,, I've confirmed that I have the correct tap (the bolt screws into the matching sized die).
The hole diameter that I need to drill I believe is 0.300"...
Is that correct? What numbered drill is this? I will have to go out and buy a good hand drill (my 3/8 7.6V hand drill wont do) and a numbered drill set.
Old Jun 30, 2004 | 08:24 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The correct drill size should be written on the tap. If not, do a google search or something, it's very common knowledge, and easy to find a table.
Notice that the hole is a special hole; the threads are about 3/8" deep down in it, and the upper part is larger. Starter bolts have a larger diameter section behind the threads that fits into that, and a corresponding fit into the starter nosepiece, that acts like a dowel pin to locate the starter positively.
Old Jul 1, 2004 | 01:27 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Call Summit. I did and got a Proform starter that can be mounted 18 or so different way and got ti to work on my late 70-s block in my 383 with a 153 tooth T5 flywheel.
Old Jul 1, 2004 | 04:04 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
same here, my mini starter mounted right up, I used the same one on my 14 inch flexplate that I did on my 12.8inch flywheel, just had to move it over to the next mounting hole on the starter.. defently not possible with any factory starter that I know of however...
Old Jul 1, 2004 | 11:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Doesn't matter what starter you use, if you don't have the bolt hole, it won't work with the small flywheel. The inner bolt would have to go RIGHT THROUGH THE MIDDLE of the starter drive.
Late 70s blocks often came with the late-model bolt hole. Blocks before about 78 did not.
Don't believe that just because somebody else bought whatever part # starter and it fit their block, that it will fit yours. You have to have the right inner bolt hole.
The 18 different way thing has nothing to do with the location of the starter shaft. All that does, is to allow the starter body to be rotated, to get clearance between it and headers or oil pan or whatever. The shaft always stays in the same place, as it would have to, since the starter has to be the right distance from the flywheel and rotating the starter motor doesn't move the flywheel around somehow.
Old Jul 2, 2004 | 12:59 AM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
ditto on the proform ministarter. it has a universal mounting plate with almost every bolt configuration you could imagine. besides that, i have never had the solenoid heatsoak and leave me stranded since i switched. with the stock starter it ate solenoids.
Street Lethal
Apr 30, 2019 12:14 PM
mhatfield 14
Oct 24, 2015 07:48 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
milk
Aug 10, 2015 06:26 PM
Elliswon
Aug 10, 2015 12:33 PM
