stuttering problem with carb..need help
Old Apr 8, 2001 | 02:30 PM
daniel dekay's Avatar
i have an 86 camaro with a newly swapped in 350 crate motor. my engine has been stumbling for a while, the dealer recommended doing a complete carb overhaul, among other things. my dad thought it would be relatively simple to get rid of the qjet for a holley or something. i passes smog in early in the year so i wont have to pass again for about another 18 months. my question here is this:should i go ahead and get the carb rebuilt(i tried once with my dad, we replaced the gaskets and stuff but it didnt solve the problem) or should i replace the carb with something that is non-computer controlled?
and if i do switch to non-comp controlled, what else do i have to switch too, to allow it to run good?
also, what are the going rates to have a 86 q-jet carb completely rebuilt?
i also heard of some G hangers or H hangers, or something like that, that may help performance?
thanks
daniel
Old Apr 8, 2001 | 07:47 PM
84FTA's Avatar
Exactly what have you done and is the computer still connected?
1984 WS6 Hardtop Trans Am
Former L69 Car under restoration
1984 T-top Trans Am
4-bolt main 350, performer intake, headers, Holley 650, T-5, hayes clutch, dual elec. fans and 3.23's.
Daily driver and restoration
13.98 @ 101
Old Apr 8, 2001 | 08:18 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
If you go w/a NON cc-carb. then you will have to get a non cc-distributor w/vacuum advance. If not this could damage the motor. But keep in mind if you do this, then your ECM will no longer be hooked up. Just something to think about.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
UNDERDRIVE PULLEY
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Old Apr 8, 2001 | 08:25 PM
so far i havent done anything. the ecm is still connected and functional. how much would a distributor like the one you are talking about(vacuum advance?) cost?
thanks for the help
daniel
Old Apr 8, 2001 | 08:27 PM
Eightyninef's Avatar
I have a stuttering problem with my speech. if it's anything like my speech it can't be fixed
Old Apr 8, 2001 | 11:41 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
You'll also need to rig the tranny to make the torque converter lock up at the right time. There is a kit from B&M or some place like that that'll take care of it for you. I think you'll also have to rig the fan, or fans, to turn on at the right temps. Or maybe not, can't remember if the computer tells the fans to turn on or not on LG4's or not, someone else will surely know.
Old Apr 9, 2001 | 06:55 PM
T/A Man's Avatar
You need to replace all the diaphrams in the carb. They have probably hardened.
Old Apr 10, 2001 | 02:55 PM
Car: 99 Formula
Axle/Gears: 342
I got my distributor from a local speed shop, it is an Accel HEI and cost me $160, but that doesn't come w/ a ignition coil.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
UNDERDRIVE PULLEY
2:73 GEARS
Old Apr 10, 2001 | 06:53 PM
Master Of Puppets's Avatar
I just got a q-jet rebuilt and it set me back ninety bucks canadian. bout sixty or so us.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
