car still stalls, and i cant figure it out???
Old Jul 7, 2004 | 04:25 PM
liquidirocz's Avatar
Car: 1986 iroc-z
Ok i have had this problem ever sense i bought this car. it only stalls when its hot and when u r on the brakes slowing down for a stop sign or red light, also if u were to put it in gear and hold youre foot on the brake. i cant figure it out i have changed the plugs, wires,cap,rotor,knock sense, iac,cleaned the throttle body, checked the maf, its a new tranny so its not the torque convertor. The engine only has 10000 miles on it, but its a reman engine and the block and heads are like a 1979, and it has the 1987 305 tpi on it. Does anyone and any clues or ideas that would help me. could it be the dist? or fuel injectors?
Old Jul 7, 2004 | 05:14 PM
StealthElephant's Avatar
Car: 87' Iroc
Does your car die instantly as soon as you hit the brakes?
Old Jul 7, 2004 | 07:46 PM
1984z28irocz's Avatar
Car: 1984 z28 ?iroc z? camaro
Transmission: auto
same problem here
i had the same problem, i would stall, and mines auto.... i adjusted the timing and it worked out, i have only stalled once or twice since and its been in reverse, it could also be your idol you may not have its set high enough
Old Jul 7, 2004 | 11:39 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Sounds like the torque convertor may be locking up at low speed and causing the stall. This is usually controled by a relay there is a way to bypass it on the trans by unpluging something but I cannot remember what. Try putting it in netrual when you are slowing down or low gear 2 or 1 and see if it does not stall. If not its probably a torque convertor issue.
Old Jul 10, 2004 | 10:21 AM
Car: 1986 iroc-z
It only stalls when ur about to stop at a light, and it only does it when its warmed up. When its cold it doesnt do it. Could it be the dist magnets are worn out?
Old Jul 10, 2004 | 11:23 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
I have the same problem of the car stalling when it is warm, plus it stall when comming to a complete stop. I, however, have a manual transmission. I just intentionally ran my gas tank bone dry and changed the inline fuel filter, then refueled the gas tank. So far, so good... no more stalling.
Have you tried changing your inline fuel filter?
Old Jul 12, 2004 | 11:06 PM
Nitrous GTA's Avatar
Car: 89' Trans am GTA
Transmission: 700-R4
my problem was the MAF car stalling at idle
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
killer777
Aug 8, 2015 02:47 PM
