Break in engine q's
Old Apr 16, 2001 | 01:31 AM
burnoutrpm's Avatar
Break in engine q's
ok dilemma...what oil, what wheight and what additives..if any should i should i put in for intial(first start up) start of a new engine?? and i absolutely WONT put in synthectics for about the first 5,000-6,000 miles! so whats best?? how about oil filters whats good to run for first run-in? whats good to run there after?(after break-in)? i was using 10w30 vavoline anf "fram" sure grip filters... bad choices? i thought maybe using 20w50 in the summer? with a delco filter? what filter asorbs the most"crap"?
89 firebird formula
356 10.5:1compression CURRENTLY DEAD!!! BEARING FAILURE!!
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
Old Apr 16, 2001 | 02:21 AM
Vader's Avatar
Burnout,
GMPP has the following recommendations for break in procedure:
Break In.pdf
I would use a detergent 10W30 mineral oil and an AC filter for the first run. AC filters have more square area of filter media than most other brands, and they are have a higher quality relief and drainback check valve.
Since your '89 should have a roller cam, you won't have any of the lithium-graphite cam break-in lube plastered all over the lobes. This stuff tends to clog a filter quickly. However, there are probably other bits and pieces of dust, dirt, lint, and debris hiding in the case in places you can't see. After the initial run of half an hour or so, spin off the oil filter and install a new one. Add enough oil to top off and run for the first 500 miles on the mineral oil. After that, you should be able to safely change to synthetic if that's what you're planning to use. GM breaks in their new engines for some vehicles with synthetics, but I would suggest that they are using different and controlled coatings on their rings and bearings to aid in faster break in with the synthetics. I would still use the mineral oil for the first 500 miles or so. If you want to wait for the first 5,000, that's O.K. Just make sure you change at 500, then 3,000. After that, you're on your own for regular maintenance.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Wylecoyote08
Nov 6, 2015 03:46 PM
MY87LT
Aug 17, 2015 08:43 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
