Are those "test noid" injector lights worth it?
Old Apr 13, 2001 | 08:29 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I was wondering if I should invest in a set of those test lights; you know, the ones that plug into the injector harness to show that the computer is sending the right signal to the injector? Is there something else I can use? Can I use a regular test light, or a digital multimeter, or make my own LED combo with a resistor & LED?
Buying the injector test lights seems to remind me of buying a $30 "code scanner" when a piece of wire and printed-out code list is all that's needed, know what I mean?
Thanks!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Apr 13, 2001 | 10:36 AM
ede's Avatar
ede
hell yes
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 13, 2001 | 12:00 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Haha, well, with a response that positive, I think I'll go pick up some new toys this weekend!
Old Apr 13, 2001 | 05:23 PM
ede's Avatar
ede
tom before you run out and buy a set of, or just one noid light. all they do is show power, or a signal in the harness to the injector. the noid light takes the place on the injector. when a signal is sent to the injector the noid light will light up, or flash. easy to see from inside the car if you're trouble shooting a no start condition.
ICON Motorsports
1st & 3rd
Old Apr 13, 2001 | 06:39 PM
Enkil's Avatar
Avoid the noid!!!
sorry, flashback. hehe
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Apr 13, 2001 | 07:17 PM
Vader's Avatar
Tom,
To answer your original qqestion, no. The test lights are probably not worth what you'll pay for one. Since there is in essence a capacitor, resistor, and LED mounted in a small case, you likely have about 45¢ in components.
However, the value of the time saved in diagnosing injector problems can be worth a lot more, and I'm thinking that is what you are really asking about. In that case, the cost is justified. I use an oscilloscope, so I not only see pulses, but can measure their actual width and duty cycle. A scope certainly isn't worth getting just for that purpose, but if you already have one...
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 14, 2001 | 06:04 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I use a 12 volt light bulb from a flashlight or running light(car bulb) with wires soldered to it. Works great. What am I missing? What would a noid light do for me?
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Apr 15, 2001 | 09:27 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I have noid lights in my toolbox, but they have pretty much stayed there. No, I'm not saying they aren't worth having, but in the 6 months I've had them, I haven't used them! Another useful one that doesn't get much use is the IAC noid light.
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Old Apr 16, 2001 | 09:05 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well, I didn't buy them... I was at the store, and paying $6 for that little plastic thing in my hand seemed strange. (Plus, the line was too damn long at the register!) I saw a new "universal" test noid light by Lisle that I might go for; it had a probe connector that could swing out for a TBI injector, or swing closed for a TPI injector. (Looks almost like a "V", it swings on it's hinge from a "-----" to a "||".) It has a large light, a long coiled wire, and a way to store the TBI adapter tip inside the housing. This one might not get lost/crunched in my toolbox, and I could drag the wire into the car to see as I turn the key.
I haven't had the occasion to use one yet either, JP84Z, but like Ede & Vader said, I think it'd be great to be able to eliminate one thing ASAP for a no-start condition. I've used my fuel pressure gauge so many times for that... if the car won't start, now, the first thing I do is check fuel pressure. I like to eliminate a system "completely", instead of thinking "hm, i guess it's firing."
Vader, what's the capacitor for inside the light? Does it act like a surge supressor and just connect parallel with the LED/resistor?
I like your idea, John; that seems pretty damn simple & effective! Wouldn't the bulb, though, pull too much current through the computer?
Old Apr 16, 2001 | 10:54 AM
Engine: 4.0L
<font face="Verdana, Arial" size="2">Originally posted by TomP:
</font>
I wouldn't think it draws any more then the fuel injector would. I have used it on a number of occasions any it works OK, just a little dim it is. I have since changed to a 6 volt bulb and it is nice and bright, easy to see in the daytime.
86 Camaro Sport
My Camaro Project
Jae992
Aug 27, 2015 09:07 AM
Brcharrelson
Aug 26, 2015 07:47 PM
GouldyGTR
Aug 21, 2015 10:43 PM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
