How does a person know when to replace a tire?
Old Jul 16, 2004 | 12:27 AM
steve's Z28's Avatar
Hi all. I have a question in regards to tire tread depth. I have a set of tires that I have had on my '91 Camaro for four years. The fronts have out side wear because it was not aligned. Anyway, what are the guidelines a person uses to determine when it is time to purchase new tires. What are the measurements that a person's refers to when determining tread measurement? What are the best tire tread depth gauges out there? Any of your responses would be greatly appreciated. Thank you.
Old Jul 16, 2004 | 12:30 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
An old trick is to use a penny. When you can see the top of Llincoln's head, its time for new ones.
Old Jul 16, 2004 | 02:13 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yup, I use Lincoln to tell me. Flip the penny over so he is "standing" on his head. When you can see the hair (I always add a slight gap), time for new rubber.
Old Jul 16, 2004 | 02:42 AM
minnesotamp's Avatar
Car: 1986 Trans Am, 2003 Silverado Z71
I have always gone by if the wire is poking threw it is time to change the tire.:lala:
Old Jul 16, 2004 | 05:31 AM
contactpatch's Avatar
Engine: sbc 350
see cord, replace tire
Old Jul 16, 2004 | 07:37 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
When you go Slip & Sliding in the rain its time for new rubber unless you are on the cheap side. How many years you have a tire is not a good reference its mieage and driving habits.
Old Jul 16, 2004 | 09:36 AM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
My car always goes slip and slide in the rain.
Old Jul 16, 2004 | 12:51 PM
DJP87Z28's Avatar
Then buy tires that handle in the wet and dry.
Old Jul 16, 2004 | 01:31 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Look at the TWI (Tread Wear Indicator) sign on the side of the tire.
When this small part of rubber is even with the rest of the profil, it's time to buy new ones!
Old Jul 16, 2004 | 01:59 PM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
Axle/Gears: 4.11 12bolt
I've read the following somewhere.
Generally, at least:
3/32 for summer
5/32 for winter
Old Jul 16, 2004 | 02:04 PM
copperhead110's Avatar
If you decide you have enough tread to keep the tires, you might want to think about putting the oddly worn front tires on the rear.
I'm basically saying put the tires with the best tread on the front.
Use the penny to get a good idea of the tread that's left.
Old Jul 16, 2004 | 02:21 PM
89IROCCVRT's Avatar
Car: '81 Camaro (Modded), '89 IROC cvrt (Stock), '00 GMC Jimmy
Engine: Modded 350 in '81, 305 TPI in '89 IROC, V6 Vortech in GMC
Transmission: T-350 in '81, 700-R4 in IROC
when your back tires are completely flat in middle (like my back tires) or when the guy you bought the car from decided to put 3 245s on and 1 250 in the front left so the car constantly pulls to the right (also just like my car)
Old Jul 18, 2004 | 10:28 AM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
Engine: 5.0 Cross Fire, 5.0 H.O.
Transmission: 4 Speed Auto, 5 Speed Manual
i got 54,000 out of my goodyears
Vintageracer
Jan 10, 2020 05:33 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
mizz0313
Aug 12, 2015 06:45 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Fronzizzle
Aug 9, 2015 01:15 PM
